Mouse Preferences
Table 7–14 lists the mouse accessibility
preferences that you can modify.
Table 7–14 Mouse Accessibility Preferences
Dialog Element
Description
Enable Mouse Keys
Select this option to make the numeric keypad emulate mouse actions. You can
set the following mouse key preferences:
Maximum pointer speed: Use the slider
or the spin box to specify the maximum speed at which the pointer moves across
the screen.
Time to accelerate to maximum speed:
Use the slider or the spin box to specify the duration of the acceleration
time of the pointer.
Delay between keypress and pointer movement:
Use the slider or the spin box to specify the period of time that must pass
after a keypress before the pointer moves.
Mouse Preferences
Click on this button to open the Mouse preference tool.
For more information about configuring the mouse accessibility preferences,
see the Java Desktop System Release 3 Accessibility Guide.
