Filter Preferences
Table 7–13 lists the keyboard accessibility
filter preferences that you can modify.
Table 7–13 Keyboard Accessibility Filter Preferences
Dialog Element
Description
Enable Slow Keys
Select this option to control the period of time that you must press-and-hold
a key before acceptance. Alternatively, to enable the slow keys feature, press-and-hold Shift for eight seconds.
You can set the following slow
keys preferences:
Only accept keys held for: Use the slider
or the spin box to specify the period of time that you must press-and-hold
Beep when key is: Select the appropriate
option or options for an audible indication when a key is pressed, accepted,
or rejected.
Enable Bounce
Keys
Select this option to accept a key input and to control the key repeat characteristics
of the keyboard. You can set the following bounce keys preferences:
Ignore duplicate keypresses within: Use
the slider or the spin box to specify the interval to wait after the first
keypress before the automatic repeat of a pressed key.
Beep if key is rejected: Select this
option for an audible indication of key rejection.
Enable Toggle
Keys
Select this option for an audible indication of a toggle keypress. You hear
one beep when a toggle key is turned on. You hear two beeps when a toggle
key is turned off.
Type to test settings
The
test area is an interactive interface so you can see how the keyboard settings
affect the display as you type. Type text in the test area to test the effect
of your settings.
For more information about configuring filter accessibility preferences,
see the Java Desktop System Release 3 Accessibility Guide.
