Enable keyboard
accessibility features
Select this option to enable keyboard accessibility features.
When you select this option, the other options in the preference tool become
available.
Disable if unused
for
Select this option to deactivate keyboard accessibility preferences if the
keyboard is not used for a specified period of time. Use the slider to specify
the number of seconds of keyboard idle time required before the system disables
the keyboard accessibility preferences. When the specified number of seconds
elapses, the following keyboard accessibility preferences are disabled:
Bounce keys
Mouse keys
Slow keys
Sticky keys
Toggle keys
Beep when features
turned on or off from keyboard
Select this option for an audible indication when a feature
such as sticky keys or slow keys is activated, or deactivated.
Import Feature
Settings
Click on this button to import an AccessX configuration
file.
Enable Sticky
Keys
Select this option to perform multiple simultaneous keypress operations by
pressing the keys in sequence. Alternatively, to enable the sticky keys feature,
press Shift five times.
You can set the following
sticky keys preferences:
Beep when modifier is pressed: Select
this option for an audible indication when you press a modifier key.
Disable if two keys pressed together:
Select this option to specify that when you press two keys simultaneously,
you can no longer press keys in sequence to perform multiple simultaneous
keypresses.
Enable Repeat
Keys
Select this option to enable the autorepeat settings for your keyboard. You
can set the following autorepeat preferences:
Delay: Use the slider or the spin box
to specify the interval to wait after the first keypress before the automatic
repeat of a pressed key.
Speed: Use the slider or the spin box
to specify the number of characters per second to enter.
Type to test settings
The
test area is an interactive interface so you can see how the keyboard settings
affect the display as you type. Type text in the test area to test the effect
of your settings.
