To access the Assistive Technology Support preference tool, click Launch, then choose Preferences -> Accessibility -> Assistive Technology Support.
Use the Assistive Technology Support preference
tool to enable assistive technologies in the Java Desktop System. You can
also use the Assistive Technology Support preference
tool to specify assistive technology applications to start automatically when
you log in.
Table 7–1 lists the assistive technology support preferences that you can modify.
Table 7–1 Assistive Technology Support Preferences|
Dialog Element |
Description |
Enable assistive technologies |
Select this option to enable assistive technologies in the Java Desktop System. |
Screenreader |
Select this option to start the |
Magnifier |
On-screen keyboard |
