To access the Desktop Background preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Display -> Desktop Background.
You can customize the desktop background in the following ways:
Select a color for the desktop background. You can select a solid color, or create a gradient effect with two colors. A gradient effect is a visual effect where one color blends gradually into another color.
Select an image for the desktop background. The image is superimposed on the desktop background color. The desktop background color is visible if you select a transparent image, or if the image does not cover the entire desktop background.
You can also change the appearance of your desktop background from within the file manager.
Table 7–2 lists the desktop background preferences that you can modify.
Table 7–2 Desktop Background Preferences
Dialog Element |
Description |
Desktop Wallpaper |
Choose an image to display on the desktop background. To choose an image, click on the Select picture button. An image selector dialog is displayed. Use the dialog to choose an image. When you choose an image, click OK. |
Style |
Use the drop-down list to specify how to display the image. Select one of the following options:
Add Wallpaper |
Click on Add Wallpaper to display the Add Wallpapers dialog. Choose the wallpaper that you want to appear as the background, then click OK. |
Remove |
Choose the Desktop Wallpaper that you want to remove, then click Remove. |
Desktop Colors |
Use the drop-down list to select one of the following options:
