To access the CD Database Server preference tool, click Launch, then choose Preferences -> Desktop Preferences -> CD Database Server.
The CD Database Server
preference tool enables
you to configure a CD database server that your system can query. A CD database
server contains information about CDs, such as the name of the artist, the
title, and the track list. When an application plays a CD, the application
can query the CD database server about the CD, then display the information.
Table 7–3 describes the
preferences in the CD Database Server
preference
tool.
Dialog Element |
Description |
Send no information |
Select this option if you do not want to send any information to the CD database server. |
Send real information |
Select this option to send your name and hostname information to the CD database server. |
Send other information |
Select this option to send another name and hostname to the CD database server. Enter the name in the Name field. Enter the hostname in the Hostname field. |
FreeDB round robin server |
FreeDB is a CD database. The FreeDB round robin server is a load-sharing configuration of FreeDB servers. Select this option to access the FreeDB CD database from this server. |
Other FreeDB server |
Select this option to access the FreeDB CD database from another server. Select the server that you require from the server table. |
Update Server List |
Click on this button to update the list of available FreeDB servers in the server table. |
Other server |
Select this option to use another CD database server. Enter the name of the server on which the database resides in the Hostname field. Enter the port number on which you can access the database in the Port field. |
