Java Desktop System Release 3 User Guide
Customizing Your Panels
To access the Panel preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Panel.
The Panel preference tool enables you to configure the behavior of panels. Any changes that you make with the Panel preference tool affect all of your panels.
Table 7–23 lists the panel preferences that you can modify:
Table 7–23 Panel Preferences
Dialog Element
Description
Close drawer when launcher is clicked
Select this option if you want a drawer on a panel to close when you choose a launcher in the drawer.
Drawer and panel animation
Select this option if you want your panels and drawers to show and to hide in an animated style.
Animation speed
Select the speed of the panel animation from the drop-down list.
