Java Desktop System Release 3 User Guide
Changing Passwords on Linux Systems
To access the Password preference tool, click Launch, then choose Preferences -> Password.
The Password preference tool enables you to change your login password. To change your login password, perform the following steps:
  1. Start the Password preference tool. A Query dialog is displayed.
  2. Enter the old password.
    Note –
    You are not prompted for the old password if you are logged on as root user.
  3. Enter the new password, then enter the new password again to confirm.
Your new password takes effect the next time you log in.
