Use the System Bell tabbed section to set your preferences for the system bell.
Some applications play a bell sound to indicate a keyboard input error. Use the preferences in the System Bell tabbed section to configure the bell sound. Table 7–43 lists the system bell preferences that you can modify.
Table 7–43 System Bell Preferences|
Dialog Element |
Description |
Sound an audible bell |
Select this option to enable the system bell. |
Visual feedback |
Select this option to enable visual feedback to indicate input errors. |
Flash window titlebar |
Select this option if you want window titlebars to flash to indicate an input error. |
Flash entire screen |
Select this option if you want the entire screen to flash to indicate an input error. |
