Use the Sound Events tabbed section of the Sound preference tool to associate particular sounds with particular
events.
You must select the Enable sound server startup option, and the Sounds for events option before you can access the components on the Sound Events tabbed section.
Table 7–42 lists the sound event preferences that you can modify.
Table 7–42 Sound Event Preferences|
Dialog Element |
Description |
Sounds table |
Use the Sounds table to associate particular sounds with particular events. The Event column displays a hierarchical list of events that can occur. To expand a category of events, click on the right arrow beside a category of events. The Sound File column lists the sound file that plays when the event occurs. |
Play |
Click on this button to play the sound file that is associated with the selected event. |
Sound file |
To associate a sound with an event, select the event in the Sounds table. Use the Sound file drop-down combination box to enter the name of the sound file that you want to associate with the selected event. Alternatively, click Browse to display a Select Sound File dialog. Use the dialog to specify the sound file that you want to associate with the selected event. Note – You can only associate .wav format sound files with events. |
