Use the Cursors tabbed section to set your mouse pointer preferences.
Table 7–21 lists the mouse pointer preferences that you can modify:
Table 7–21 Mouse Pointer Preferences|
Dialog Element |
Description |
Small |
Select this option to display a small mouse pointer. |
Medium |
Select this option to display a medium mouse pointer. |
Large |
Select this option to display a large mouse pointer. |
Highlight the pointer when you press Ctrl |
Select this option to enable a mouse pointer animation when you press and release Ctrl. This feature can assist you to locate the mouse pointer. |
