Use the Motion tabbed section to set your preferences for mouse movement.
Table 7–22 lists the mouse motion preferences that you can modify:
Table 7–22 Mouse Motion Preferences|
Dialog Element |
Description |
Acceleration |
Use the slider to specify the speed at which your mouse pointer moves on your screen when you move your mouse. |
Sensitivity |
Use the slider to specify how sensitive your mouse pointer is to movements of your mouse. |
Threshold |
Use the slider to specify the distance that you must move an item before the move action is interpreted as a drag-and-drop action. |
