You can install new controls options, window frame options, or icons options. You can find many controls options on the Internet.
To install a new controls option, window frame option, or icons option, perform the following steps:
Start the Theme preference tool.
Click on the Theme Details button.
Click on a tab in the Theme Details dialog for the type of theme that you want to install. For example, to install an icons option, click on the Icons tab.
Click on the Install Theme button.
Enter the location of the option archive file in the drop-down combination box of the Theme Installation dialog. Alternatively, to browse for the file, click on the Browse button. When you have selected the file, click Open.
Click on the Install button to install the new option.
