Java Desktop System Release 3 User Guide
To Delete a Theme
You can delete controls options, window frame options, or icons options.
To delete a controls option, window frame option, or icons option, perform the following steps:
  1. Start the Theme preference tool.
  2. Click on the Theme Details button.
  3. Click on a tab in the Theme Details dialog for the type of option that you want to delete.
  4. Click on the Go to Theme Folder button. A file manager window opens on the default option folder.
  5. Use the file manager window to delete the option.
