Use the General tabbed section to view and to modify information about the selected printer, such as the printer name and location.Table 7–27 lists the general options that you can modify.
Table 7–27 General Options
Dialog Element |
Description |
Name |
Shows the name of the selected printer. |
Description |
Provides a brief description of the selected printer. |
Location |
Shows the location of the selected printer. |
Resolution |
Use the drop-down list to select the resolution to use for the printer. |
Status |
Shows the status of the selected printer. |
Print a Test Page |
Click to print a test page. |
