Java Desktop System Release 3 User Guide
To Set Paper Options
Use the Paper tabbed section to specify paper values, and to choose the paper layout for the selected printer.
Table 7–28 lists the paper options that you can specify.
Table 7–28 Paper Options
Dialog Element
Description
Paper size
Use the drop-down list to select the paper size to use for the printer.
Paper type
Use the drop-down list to select the paper type to use for the printer.
Source
Use the drop-down list to select the paper tray to use for the printer. The source specifies where the paper is located in the printer.
Double Sided
Use the drop-down list to select the layout to use for the printer.
