Use the Advanced tabbed section to specify advanced values for the selected printer.
Table 7–29 lists an example of advanced options that you can specify for a specific printer.
Table 7–29 Advanced Options
Dialog Element |
Description |
Floyd-Steinberg Dithering |
Use the drop-down list to select the type of dithering to use for the printer, for example, Floyd-Steinberg dithering. |
Manual Feed of Paper |
Use the drop-down list to select whether you want to switch on or off the paper manual feed. |
Page Region |
Use the drop-down list to select the paper size to use for the printer. |
Number of Copies |
Use the drop-down list to select the number of copies that you want to print. |
Density |
Use the drop-down list to select the density to use for the printer. |
Economy mode |
Use the drop-down list to select the economy mode to use for the printer. |
RET Setting |
Use the drop-down list to select the Resolution Enhancement Technology (RET) setting to use for the printer. RET inserts smaller dots at the edges of lines and smooths any rough edges. |
