Customizing Keyboard Shortcuts
To access
the Keyboard Shortcuts preference tool, click Launch, then choose Preferences -> Desktop Preferences -> Keyboard -> Shortcuts.
A keyboard shortcut is a key or combination of
keys that provides an alternative to standard ways of performing an action.
Use the Shortcuts preference tool to display
the default keyboard shortcuts. You can customize the default keyboard shortcuts
to your requirements. In addition, you can also set shortcut key preferences
for multimedia functions.
You can also create hot keys on Solaris systems.
Hot keys are keyboard shortcuts that start applications.
Table 7–17 lists the keyboard shortcut settings
that you can customize on Linux systems.
Table 7–17 Keyboard Shortcuts Preferences on Linux Systems
Dialog Element
Description
Text editing shortcuts
Select
one of the following settings:
Desktop shortcuts
This
table lists several actions and the shortcut keys that are associated with
each action.
To change the shortcut keys for an action, click
on the action to select the action, then press the keys that you want to associate
with the action.
To disable the shortcut keys for an action, click
on the action to select the action, then press Back Space.
Table 7–18 lists the keyboard shortcut settings
that you can customize on Solaris systems.
Table 7–18 Keyboard Shortcuts Preferences on Solaris Systems
Dialog Element
Description
Select
Desktop shortcuts
This
each action.
with the action.
Custom Shortcuts
To add a hot key,
perform the following steps:
Click New. A Custom Binding dialog is displayed. Enter the command to associate with the hot
key in the New Command field. Alternatively, to browse
for the command, click on the Browse button. When you
have selected the command, click OK. The command is
added to the Custom Shortcuts section of the Desktop shortcuts table.
Click in the Shortcut column of the
command in the Custom bindings section of the Desktop shortcuts table. Press the key or key combination that
you want to associate with the command.
To edit a hot key, select the hot key in the Custom Shortcuts section of the Desktop shortcuts
table, then click Edit. Edit the command in the Custom Binding dialog.
To remove a hot key, select
the hot key in the Custom Shortcuts section of the Desktop shortcuts table, then click Delete.
Multimedia keys table
To add the shortcut keys for an action, click
with the action.
Use PCM volume instead of Master
volume
Select this
option if you want to use Pulse Code Modulation (PCM) volume instead of Master
volume.
