Customizing Menus and Toolbars in Applications
To access the Menus & Toolbars preference tool, click Launch,
then choose Preferences -> Desktop Preferences -> Display -> Menus & Toolbars.
You can use the Menus & Toolbars preference
tool to customize the appearance of menus, menubars, and toolbars for GNOME-compliant
applications.
Table 7–19 lists the menu and toolbar preferences
that you can modify for GNOME-compliant applications.
Table 7–19 Menu and Toolbar Preferences
Dialog Element
Description
Show icons in menus
Select this option to display an icon beside
each item in a menu. Some menu items do not have an icon.
Detachable toolbars
Select this option if you want to move toolbars
from application windows to any location on the screen. If you select this
option, handles are displayed on the left side of the toolbars in your applications.
To move a toolbar, click-and-hold the handle, then drag the toolbar to the
new location.
Toolbar button labels
Choose one of the following options to specify
what to display on the toolbars in your GNOME-compliant applications:
Text below icons: Select this option
to display text as well as an icon on each toolbar button.
Text beside icons: Select this option
to display an icon only on each toolbar button, and with text on the most
important toolbar buttons.
Icons only: Select this option to display
an icon only on each toolbar button.
Text only: Select this option to display
text only on each toolbar button.
Preview
Displays a preview of
the selected toolbar button label.
