Use the Web Browser
tabbed section to configure your preferred web browser. The preferred web
browser opens when you click on a URL. For example, the preferred web browser
opens when you select a URL in an application, or when you select a URL launcher
on the desktop background.
Table 7–30 lists the preferred web browser preferences that you can modify.
Table 7–30 Preferred Web Browser Preferences
Dialog Element |
Description |
Select a Web Browser |
Select this option if you want to use a standard web browser. Use the drop-down combination box to select your preferred web browser. |
Custom Web Browser |
Select this option if you want to use a custom web browser. |
Command |
Enter the command to start the custom web browser. To enable the browser to display a URL that you click on, include “%s” after the command. |
Start in Terminal |
Select this option to run the command in a terminal window. Select this option for a browser that does not create a window in which to run. |
