Use the Mail Reader
tabbed section to configure your preferred email client.
Table 7–31 lists the preferred email client preferences that you can modify.
Table 7–31 Preferred Email Client Preferences
Dialog Element |
Description |
Select a Mail Reader |
Select this option if you want to use a standard email client. Use the drop-down combination box to select your preferred email client. |
Custom Mail Reader |
Select this option if you want to use a custom email client. |
Command |
Enter the command to start the custom email client. |
Start in Terminal |
Select this option to run the command in a terminal window. Select this option for an email client that does not create a window in which to run. |
