Java Desktop System Release 3 User Guide
Text Editor Preferences
Use the Text Editor tabbed section to configure your preferred text editor.
Table 7–32 lists the preferred text editor preferences that you can modify.
Table 7–32 Preferred Text Editor Preferences
Dialog Element
Description
Select an Editor
Select this option if you want to use a standard text editor. Use the drop-down combination box to specify your preferred text editor.
Custom Editor
Select this option if you want to use a custom text editor. A Custom Editor Properties dialog is displayed.
  • Name: Type the name of the custom text editor.
  • Command: Enter the command to start the custom text editor.
  • This application can open multiple files: Select this option if the default text editor can open multiple files.
  • This application needs to be run in a shell: Select this option to run the command in a terminal window. Select this option for an editor that does not create a window in which to run.
After you specify a custom text editor, you can click on the Properties button to display the Custom Editor Properties dialog. You can use the dialog to modify the properties of the custom text editor.
Use this editor to open text files in the file manager
Select this option if you want the file manager to start the custom text editor to display text files.
