Use the Terminal
tabbed section
to configure your preferred terminal.
Table 7–33 lists the preferred terminal preferences that you can modify.
Table 7–33 Preferred Terminal Preferences
Dialog Element |
Description |
Select a Terminal |
Select this option if you want to use a standard terminal. Use the drop-down combination box to specify your preferred terminal application. |
Custom Terminal |
Select this option if you want to use a custom terminal application. |
Command |
Enter the command to start the custom terminal. |
Exec Flag |
Enter the exec option to use with the command application. |
