Java Desktop System Release 3 User Guide
To Add a Launcher
A desktop background launcher can start an application or link to a particular file, folder, FTP site, or URI location.
To add a launcher to your desktop background, perform the following steps:
  1. Right-click on the desktop background, then choose Create Launcher.
  2. Type the required information in the Create Launcher dialog. The command that you enter for the launcher is the command that is executed when you use the desktop background object.
