Java Desktop System Release 3 User Guide
To Open an Object
To open an object from the desktop background, double-click on the object. Alternatively, right-click on the object, then choose Open. When you open an object, the default action for the object executes. For example, if the object is a text file, the text file opens in a file manager window. The default actions for file types are specified in the File Associations preference tool.
To execute an action other than the default action for an object, right-click on the object, then choose Open With. Choose an action from the Open With submenu.
The items in the Open With submenu correspond to the contents of the following parts of the File Associations preference tool:
You can set your preferences in a file manager window so that you click once on a file to execute the default action.
