Java Desktop System Release 3 User Guide
To Select an Object
To select an object on the desktop background, click on the object. To select multiple objects, press-and-hold Ctrl, then click on the objects that you want to select.
You can also select an area on the desktop background to select all objects within that area. Click-and-hold on the desktop background, then drag over the area that contains the objects that you want to select. When you click-and-hold then drag, a rectangle appears to mark the area that you select.
To select multiple areas, press-and-hold Ctrl, then drag over the areas that you want to select.
