Drag-and-Drop in the File Manager
You can use drag-and-drop to perform several tasks in the file manager.
When you drag-and-drop, the mouse pointer provides feedback about the task
that you perform. Table 5–4 describes the tasks
that you can perform with drag-and-drop. The table also shows the mouse pointers
that appear when you drag-and-drop.
Table 5–4 Drag-and-Drop in the File Manager
Task
Action
Mouse Pointer
Move an item
Drag the item to the new location.
Copy an item
Grab the item, then press-and-hold Ctrl. Drag the item to the new location.
Create a symbolic link to
an item
Grab the
item, then press-and-hold Ctrl + Shift.
Drag the item to the location where you want the symbolic link to reside.
Ask what to do with the
item you drag
Grab the item, then press-and-hold Alt. Drag the item to
the location where you want the item to reside. Release the mouse button.
A popup menu appears. Choose one of the following items from the popup menu:
Move here
Moves the item to the location.
Copy here
Copies the item to the location.
Link here
Creates a symbolic link to the item at the location.
Set as Background
If the item is an image, sets the image to be the desktop background.
You can use this command to set the desktop background and the view pane
background.
Cancel
Cancels the drag-and-drop operation.
