You can display the contents of a folder in any of the following ways:
Double-click on the folder in the view pane.
In the Location field, type the path of the folder that you want to display, then press Return. The Location field includes an autocomplete feature. As you type a path, the file manager reads your file system. When you type enough characters to uniquely identify a directory, the file manager completes the name of the directory in the Location field.
Use the Tree in the side pane. For more information, see Using the Tree From the Side Pane.
Use the Back toolbar button and the Forward toolbar button to browse through your navigation history.
To change to the folder that is one level above the current folder, choose Go -> Up. Alternatively, click on the Up toolbar button.
To reload the display, click on the Reload button.
If you cannot find the folder that you want to display, you can use Search Tool
. To start the Search Tool
click Launch, then choose Find Files.
