The Tree displays a hierarchical representation of your file system. The Tree provides a convenient way to navigate your file system. To display the Tree in the side pane, choose Tree from the drop-down list at the top of the side pane.
In the Tree, folders are represented as follows:
Folder State |
Graphic Representation |
Closed folder |
Right arrow |
Open folder |
Down arrow |
Table 5–2 describes the tasks that you can perform with the Tree, and how to perform the tasks.
Table 5–2 Tree Tasks|
Task |
Action |
Open the Tree. |
Choose Tree from the drop-down list at the top of the side pane. |
Close the Tree. |
Choose another item from the drop-down list at the top of the side pane. |
Open a folder in the Tree. |
Click on the arrow next to the folder in the Tree. |
Close a folder in the Tree. |
Display the contents of a folder in the view pane. |
Select the folder in the Tree. |
Display the contents of a file in the view pane. |
Select the file in the Tree. |
You can set your preferences so that the Tree does not display files.
