To Set List Columns Preferences
You can specify what information is displayed in list view in file manager
windows. For example, you can specify which columns are displayed and the
order in which the columns are displayed.
To set your preferences for list columns in the File Management dialog, click on the List Columns tab to
display the List Columns tabbed section. To specify a
column to display in list view, select the option that corresponds to the
column, then click on the Show button. To remove a
column from the list view, select the option that corresponds to the column,
then click on the Hide button.
Use the Move Up and Move Down
buttons to specify the position of columns in list view.
To use the default columns and column positions, click on the Use Default button.
The following table describes the columns that you can display:
Information
Description
Name
Select this option to display the name of
the item.
Size
the size of the item.
Type
the description of the MIME type of the item from the File Associations preference tool.
Date Modified
Select
this option to display the last modification date of the item.
Date Accessed
Select
this option to display the date that the item was last accessed.
Group
Select this option to display the group to
which the item belongs.
MIME Type
Select this option to display the MIME type
of the item.
Octal Permissions
Select this
option to display the permissions of the item in octal notation, for example 764.
Owner
the owner of the item.
Permissions
Select
this option to display the permissions of the item as three sets of three
characters, for example -rwxrw-r--.
