To Set Icon Caption Preferences
An icon caption displays the name of a file or folder in
an icon view. The icon caption also includes three additional items of information
on the file or folder. The additional information is displayed after the file
name. Normally only one item of information is visible, but when you zoom
in on an icon, more of the information is displayed. You can modify what additional
information is displayed in icon captions.
To set your preferences for icon captions in the File Management
Preferences dialog, click on the Icon Caption
tab.
Use the drop-down lists to select the items of information that you
want to display in the icon caption. The following table describes the items
of information that you can select from each drop-down list:
Information
Description
Size
Choose this option to display
the size of the item.
Type
the description of the MIME type of the item from the File Associations preference tool.
Date Modified
Choose
this option to display the last modification date of the item.
Date Accessed
Choose
this option to display the date that the item was last accessed.
Owner
the owner of the item.
Group
the group to which the item belongs.
Permissions
Choose
this option to display the permissions of the item as three sets of three
characters, for example -rwxrw-r--.
Octal Permissions
Choose this option to display the permissions of the item in octal
notation, for example 764.
MIME Type
the MIME type of the item.
None
no information for the item.
