Java Desktop System Release 3 User Guide
To Set Behavior Preferences
To set behavior preferences for files and folders, click on the Behavior tab in the File Management Preferences dialog.
Table 7–7 lists the behavior preferences that you can modify for files and folders.
Table 7–7 File Management Behavior Preferences
Dialog Element
Description
Single-click to activate items
Select this option to perform the default action for an item when you click on the item. When this option is selected, and you point to an item, the title of the item is underlined.
Double-click to activate items
Select this option to perform the default action for an item when you double-click on the item.
Run executable text files when they are clicked
Select this option to run an executable file when you click on the executable file. An executable file is a text file that can execute, that is, a shell script.
View executable text files when they are clicked
Select this option to display the contents of an executable file when you click on the executable file.
Ask each time
Select this option to display a dialog when you click on an executable file. The dialog asks whether you want to execute the file or display the file.
Ask before emptying the Trash or deleting files
Select this option to display a confirmation message before Trash is emptied, or files are deleted.
Include a Delete command that bypasses Trash
Select this option to add a Delete menu item to the following menus:
  • The Edit menu
  • The popup menu that is displayed when you right-click on a file, folder, or desktop background object
When you select an item, then choose the Delete menu item, the item is deleted from your file system immediately.
