Java Desktop System Release 3 User Guide
Cut and Paste to the New Location
You can cut a file or folder and paste the file or folder into another folder, as follows:
  1. Select the file or folder that you want to move, then choose Edit -> Cut File.
  2. Open the folder to which you want to move the file or folder, then choose Edit -> Paste Files.
