Java Desktop System Release 3 User Guide
To Navigate Your History List Using History in the Side Pane
To display the History list in the side pane, choose History from the drop-down list at the top of the side pane. The History list in the side pane displays a list of your previously-viewed items.
To display an item from your history list in the view pane, click on the item in the History list.
