To browse the applications in the current session, use the Sessions preference tool. The Current Session
tabbed section lists the following:
All Java Desktop System applications that are currently running, that can connect to the session manager, and that can save the state of the application.
All preference tools that can connect to the session manager, and that can save the state of the tool.
You can use the Current Session tabbed section to perform a limited number of actions on the session properties of an application or preference tool. For example, you can edit the startup order or restart style of any Java Desktop System application or preference tool that is in the list.
