You can configure your sessions to start applications
that are not session-managed. To configure non-session-managed startup applications,
use the Sessions
preference tool. Use the Startup Programs tabbed section to add, edit, and delete applications.
If you save your settings and log out, the startup applications start automatically
the next time that you log in.
