Java Desktop System Release 3 Accessibility Guide
2.2.2 To Enable the Keyboard to Emulate the Mouse
The mouse keys feature enables you to use the numeric keypad on the keyboard to emulate mouse actions. This feature benefits users who have difficulty using a mouse or other pointing device. To enable and configure the mouse keys feature, perform the following steps:
  1. Click Launch, then choose Preferences -> Accessibility -> Keyboard.
  2. Click on the Mouse Keys tab.
  3. Select the Enable Mouse Keys option.
  4. Configure the following options to determine the behavior of the mouse pointer when you control the pointer from the numeric keypad:
    Maximum pointer speed
    Use this spin box to specify the maximum speed, in pixels per second, at which the pointer moves around the screen.
    Time to accelerate to maximum speed
    Use this spin box to specify the duration, in milliseconds, before the pointer accelerates to the maximum pointer speed.
    Delay between keypress and pointer movement
    Use this spin box to specify the interval, in milliseconds, between a keypress and the time when the pointer starts to move.
When you enable mouse keys, the keys on the numeric keypad have the following functions:
Table 2–1 Numeric Keypad to Mouse Function Mapping on Solaris Systems
Numeric Keypad Keys
Function
1, 2, 3, 4, 6, 7, 8, 9
Move the mouse pointer around the screen
5
Mouse button click
0
Mouse button double-click
Mouse button press
Mouse button 1
Mouse button 2
Mouse button 3
Table 2–2 Numeric Keypad to Mouse Function Mapping on Linux Systems
Numeric Keypad Keys
Function
5
Mouse button click
0
Mouse button 3
Some Solaris systems also use the function keys to emulate the mouse buttons. The common function key to mouse button mappings are described in the following table.
Table 2–3 Function Key to Mouse Function Mapping on Solaris Systems
Function Key
Function
F2
Mouse button 1
F3
Mouse button 2
F4
Mouse button 3
