Java Desktop System Release 3 Accessibility Guide
3.9.4 To Navigate Check Boxes
A check box is a control that you use to select or deselect an option.
Figure 3–3 Sample Check Box
Sample check box.
The following table lists the keyboard shortcuts that you can use to navigate a check box.
Keys
Function
spacebar
Select or deselect the check box.
