Text boxes are controls in which you type text.
The following table lists the keyboard shortcuts that you can use to navigate a single line text box.
Keys |
Function |
left arrow |
Position the cursor one character to the left. |
right arrow |
Position the cursor one character to the right. |
Ctrl + left arrow |
Position the cursor at the start of the current word. Press-and-hold Ctrl and continue to press left arrow to position the cursor at the start of the previous word. |
Ctrl + right arrow |
Position the cursor at the end of the current word. Press-and-hold Ctrl and continue to press right arrow to position the cursor at the end of the next word. |
Home |
Position the cursor at the start of the line. |
End |
Position the cursor at the end of the line. |
Shift + left arrow or right arrow |
Select one character at a time to the left or right of the cursor. |
Shift + Ctrl + left arrow or right arrow |
Select one word at a time to the left or right of the cursor. |
Shift + Home |
Select all text to the left of the cursor. |
Shift + End |
Select all text to the right of the cursor. |
Ctrl + A (Solaris only) |
Select all text in the text box. |
In addition to the keyboard shortcuts listed in the previous table, use the keyboard shortcuts in the following table to navigate multi-line text boxes.
Keys |
Function |
Page Up |
Position the cursor at the top of the current view. Press Page Up again to position the cursor at the top of the previous view. |
Page Down |
Position the cursor at the end of the current view. Press Page Down again to position the cursor at the end of the previous view. |
Ctrl + up arrow |
Position the cursor at the start of the current paragraph. Press-and-hold Ctrl and continue to press the up arrow key to position the cursor at the start of the previous paragraph. |
Ctrl + down arrow |
Position the cursor at the end of the current paragraph. Press-and-hold Ctrl and continue to press the down arrow key to position the cursor at the end of the next paragraph. |
Ctrl + Page Up |
Position the cursor one view width to the left. |
Ctrl + Page Down |
Position the cursor one view width to the right. |
Ctrl + Home |
Position the cursor at the start of the text box. |
Ctrl + End |
Position the cursor at the end of the text box. |
Ctrl + Tab |
Give focus to the next control on the dialog. |
Shift + Page Up |
Select the text to the start of the current view. Press-and-hold Shift and continue to press Page Up to extend the selection to the start of the previous view. |
Shift + Page Down |
Select the text to the end of the current view. Press-and-hold Shift and continue to press Page Down to extend the selection to the end of the next view. |
Shift + Home |
Select the text to the start of the line. |
Shift + End |
Select the text to the end of the line. |
Shift + Ctrl + up arrow |
Select the text to the start of the paragraph, then to the start of the previous paragraph. |
Shift + Ctrl + down arrow |
Select the text to the end of the paragraph, then to the end of the next paragraph. |
Shift + Ctrl + Home |
Select the text to the start of the text box. |
Shift + Ctrl + End |
Select the text to the end of the text box. |
