A slider is a control that you use to set a value in a continuous range of values.
The following table describes the keyboard shortcuts that you can use to navigate a slider.
Keys |
Function |
left arrow or up arrow |
Move the slider left or up by a small amount. |
right arrow or down arrow |
Move the slider right or down by a small amount. |
Page Up |
Move the slider left or up a large amount. |
Page Down |
Move the slider right or down a small amount. |
Home |
Move the slider to the maximum value. |
End |
Move the slider to the minimum value. |
