Windows and dialogs are sometimes divided into logical sections that are displayed one section at a time on the window or dialog. The divisions are called tabbed sections that are identified by a tab with a text label.
The following table lists the keyboard shortcuts that you can use to navigate the tabbed sections of a window or dialog when a tab name has focus.
Keys |
Function |
left arrow |
Give focus to the previous tabbed section. |
right arrow |
Give focus to the next tabbed section. |
Tab orCtrl + down arrow |
Give focus to the first control on the active tabbed section. |
The following table lists the keyboard shortcuts that you can use to navigate the tabbed sections of a window or dialog when a control on a tabbed section has focus.
Keys |
Function |
Ctrl + Page Up or Ctrl + Alt + Page Up |
Give focus to the previous tabbed section. This keyboard shortcut does not work if the focused control uses Ctrl+ Page Up for another purpose. |
Ctrl + Page Down or Ctrl + Alt + Page Down |
Give focus to the next tabbed section. This keyboard shortcut does not work if the focused control uses Ctrl+ Page Down for another purpose. |
Ctrl + Tab |
Give focus to the next control outside the tabbed sections. |
