The following table lists the keyboard shortcuts that you can use to navigate multi-column lists when a column header has focus.
Keys |
Function |
left arrow or right arrow |
Give focus to the previous or next column header. |
spacebar |
Activate the header. This action usually sorts the list by the column header. |
Tab |
Give focus to the list contents. |
The following table lists the keyboard shortcuts that you can use to navigate lists when the contents of the list has focus.
Keys |
Function |
arrow keys |
Select the next or previous row or column. |
Page Up |
Select the top row of the list contents that are in view. Press Page Up again to select the top row of the previous view. |
Page Down |
Select the bottom row of the list contents that are in view. Press Page Down again to select the bottom row of the next view. |
Home |
Select the first row in the list. |
End |
Select the last row in the list. |
Shift + arrow keys |
For lists that support multi-line selections, add the next or previous row or column to the current selection. For lists that only allow single line selections, select the next or previous row or column. |
Shift + Page Up |
Select all the rows between the current selection and the top row of the view. |
Shift + Page Down |
Select all the rows between the current selection and the bottom row of the view. |
Shift + Home |
Select all the rows between the current selection and the first row in the list. |
Shift + End |
Select all the rows between the current selection and the last row in the list. |
Ctrl + arrow keys |
Give focus to the next row or column but do not extend the selection. |
Ctrl + Page Up |
Give focus to the top row in the view but do not extend the selection. |
Ctrl + Page Down |
Give focus to the bottom row in the view but do not extend the selection. |
Ctrl + Home |
Give focus to the first row in the list but do not extend the selection. |
Ctrl + End |
Give focus to the last row in the list but do not extend the selection. |
Return |
Activate the item. |
Ctrl + A |
For lists that support multiline selections, select all rows in the list. |
Shift + Tab |
Give focus to the column header, if applicable. |
