名前 | 形式 | 機能説明 | オプション | 終了ステータス | 属性 | 関連項目 | 注意事項
/usr/sbin/mdmonitord [-t time_interval]
The mdmonitord utility is part of Solaris Volume Manager. It monitors and checks RAID1 (mirrors), RAID5 and hot spares.
There are two methods for checking:
At fixed time intervals.
When a RAID-1 (mirror), RAID-5, or hot spare fails. A failure generates an error event which triggers a check of these metadevices.
The following options are supported:
Time interval in seconds. The default value is 0, which causes probes to occur only upon an error. If you want to run mdmonitord at a regular interval, a value of 1800 (seconds, every half hour) is recommended as a starting point.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWmdu  |
svcs(1), metaclear(1M), metadb(1M), metadetach(1M), metahs(1M), metainit(1m), metaoffline(1M), metaonline(1M), metaparam(1M), metarecover(1M), metarename(1M), metareplace(1M), metaroot(1M), metaset(1M), metassist(1M), metastat(1M), metasync(1M), metattach(1M), svcadm(1M), md.tab(4), md.cf(4), mddb.cf(4), md.tab(4), attributes(5), smf(5), md(7D)
Since frequent probes can affect performance, it is recommended that the intervals between probes be limited.
The mdmonitord service is managed by the service management facility, smf(5), under the service identifier:
svc:/system/mdmonitor  |
Administrative actions on this service, such as enabling, disabling, or requesting restart, can be performed using svcadm(1M). The service's status can be queried using the svcs(1) command.
