This chapter provides step-by-step instructions for installing the Solaris 10 Operating System (Solaris OS) on IBM BladeCenter servers. The instructions that are included in this chapter apply to the following Solaris 10 releases:
Solaris 10 8/07
Solaris 10 11/06
Solaris 10 6/06
Solaris 10 1/06
Instructions for preparing a system for installation, as well as instructions for performing an installation of client systems from the network and for performing a stand-alone installation are described in detail. More information about IBM BladeCenter servers can be found at http://www.ibm.com/systems/bladecenter/.
This is a list of the information in this chapter:
Preparing to Install the Solaris Operating System on IBM BladeCenter Servers (Task Map)
Preconfiguring System Configuration Information With the DHCP Service (Task Map)
Several of the tasks in this chapter are part of the preparation for installing the Solaris 10 OS on IBM BladeCenter servers. Depending on your situation, you might not need to perform all of these tasks. Review the individual task maps first to determine which tasks are required for the type of installation you are performing.
Starting with the Solaris 10 1/06 release, the open source GNU GRand Unified Bootloader (GRUB) has been implemented on x86 based systems. GRUB is the boot loader that is responsible for loading a boot archive into a system's memory. The boot archive contains the kernel modules and configuration files that are required to boot the system. The most notable change is the replacement of the Device Configuration Assistant with the GRUB menu. This menu is displayed when the system is booted. This document includes task-related information for installing and booting a system with GRUB.
GRUB implements a simple menu interface that includes boot options that are predefined in a configuration file. GRUB also has a command-line interface that is accessible from the menu interface for performing various boot commands. The GRUB implementation on x86 based systems in the Solaris OS is compliant with the Multiboot Specification. For more information about this boot loader package, do an Internet search on “GNU GRUB.”
For more information about GRUB, refer to the following documentation:
For step-by-step instructions on booting a Solaris system, see Chapter 11, GRUB Based Booting (Tasks), in System Administration Guide: Basic Administration.
For installation instructions, see the following documentation:
If you are installing with the Solaris interactive installation program, see Solaris 10 Installation Guide: Basic Installations.
If you are installing with the custom JumpStartTM program, see Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
If you need to set up an installation server to install over the network, see Solaris 10 Installation Guide: Network-Based Installations.
If you are installing or upgrading with Solaris Live Upgrade, see Solaris 10 Installation Guide: Solaris Live Upgrade and Upgrade Planning.
For information about managing devices and file systems, see Disk Management in the GRUB Boot Environment in System Administration Guide: Devices and File Systems.
The complete set of Solaris installation and system administration documentation can be found at http://docs.sun.com.
For a listing of all the new features in the Solaris 10 OS, see the Solaris 10 What’s New.
This chapter describes how to install the Solaris OS on IBM BladeCenter servers, starting with the Solaris 10 1/06 release.
Installation information for the following IBM BladeCenter Servers is included:
AMD Opteron LS20 for IBM BladeCenter
AMD Opteron LS21 for IBM BladeCenter
AMD Opteron LS41 for IBM BladeCenter
Intel Xeon IBM BladeCenter HS20
Intel Xeon IBM BladeCenter HS21
Intel Xeon IBM BladeCenter HS40
For additional information about installing the Solaris 10 8/07 and Solaris 10 11/06 OS on the BladeCenter LS21, LS41, and HS21 servers, see the appropriate sections under Chapter 3, Troubleshooting Installation Issues on IBM BladeCenter Servers (Tasks).
See the following resources for additional hardware-specific installation instructions:
Information about the AMD Opteron LS20 for IBM BladeCenter (Type 8850) can be found at:
Information about the Intel Xeon IBM BladeCenter HS20 (Type 7981) can be found at:
Information about the Intel Xeon IBM BladeCenter HS20 (Type 8843) can be found at:
Information about the Intel Xeon IBM BladeCenter HS40 (Type 8839) can be found at:
Before you begin the installation process, see Chapter 2, Bugs and Issues Encountered When Installing the Solaris Operating System on IBM BladeCenter Servers for information about bugs and issues you need to be aware of before installing and running the Solaris OS on IBM BladeCenter servers.
Also, see Chapter 3, Troubleshooting Installation Issues on IBM BladeCenter Servers (Tasks) for additional information that pertains to installing the Solaris 10 OS on IBM BladeCenter servers.
Task |
Description |
For Instructions |
Use the setup_install_server command to copy the Solaris 10 OS to the installation server's disk from CD. | ||
Create an x86 installation server with DVD media. |
Use the setup_install_server command to copy the Solaris 10 OS to the installation server's disk from DVD. |
Before you can install the Solaris OS on client systems, you must first set up an installation server. The tasks that are necessary for performing a network installation by using this method are described in this section. If you are installing the Solaris OS on a stand-alone system, see Performing an Installation With the Solaris Installation Program on IBM BladeCenter Servers (Stand-Alone).
The procedure for setting up an installation server with CD media differs from the procedure for setting up an installation server with DVD media. Use the procedure that is appropriate for the installation media you have selected.
The installation server contains the installation image that is needed to install the Solaris software on systems from the network. You must create an installation server to install the Solaris software on a system from the network. You do not always need to set up a separate boot server. Refer to the following guidelines to determine whether you need to set up a separate boot server.
If you are using DHCP to set installation parameters, or if your installation server and client are on the same subnet, you do not need a separate boot server. For information about how to configure the DHCP client, see Chapter 16, Configuring and Administering the DHCP Client, in System Administration Guide: IP Services.
If your installation server and your client are not on the same subnet and you are not using DHCP, you must create separate boot servers for each subnet. You could create an installation server for each subnet. However, installation servers require more disk space.
This procedure assumes that the system is running Solaris Volume Manager. If you are not using Solaris Volume Manager to manage media, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Solaris Volume Manager.
On the system that is to become the installation server, become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
The system must include a CD-ROM drive and be part of the site's network and name service. If you do not use a name service, you must distribute information about this system by following your site's policies.
Insert the Solaris installation CD into the system's drive.
Create a directory for the CD image.
# mkdir -p install-dir-path |
install-dir-path – Specifies the directory where the CD image is to be copied.
Change to the Tools directory on the mounted disc.
# cd /cdrom/cdrom0/Solaris_10/Tools |
where cdrom0 is the path to the drive that contains the Solaris OS CD media.
Copy the image in the drive to the installation server's hard disk.
# ./setup_install_server install-dir-path |
The setup_install_server command indicates whether you have enough disk space available for the Solaris Software disc images. To determine available disk space, use the df -kl command.
Decide if you need to make the installation server available for mounting.
If the installation server is on the same subnet as the system to be installed or you are using DHCP, you do not need to create a boot server. Proceed to Step 7.
If the installation server is not on the same subnet as the system to be installed and you are not using DHCP, complete the following steps:
Verify that the path to the installation server's image is shared appropriately.
# share | grep install-dir-path |
Make the installation server available by adding this entry to the /etc/dfs/dfstab file.
share -F nfs -o ro,anon=0 -d "install server directory" install-dir-path |
Verify that the nfsd daemon is running.
Share the installation server.
# shareall |
Change to the root (/) directory.
# cd / |
Eject the Solaris Software - 1 CD.
Insert the Solaris Software - 2 CD into the system's CD-ROM drive.
Change to the Tools directory on the mounted CD.
Copy the CD in the CD-ROM drive to the installation server's disk.
# ./add_to_install_server install-dir-path |
Change to root (/) directory.
# cd / |
Eject the Solaris Software - 2 CD.
Repeat Step 9 through Step 13 for each Solaris Software CD installation.
Insert the Solaris Languages CD into the system's CD-ROM drive.
# cd /cdrom/cdrom0/Tools |
# cd / |
Determine if you need to create a boot server.
If the installation server is not on the same subnet as the system to be installed or you are not using DHCP, you need to create a boot server. For more information, see To Create a Boot Server on a Subnet With a CD Image in Solaris 10 Installation Guide: Network-Based Installations.
If you are using DHCP or the installation server is on the same subnet as the system to be installed, you do not need to create a boot server.
When you have finished setting up the installation server, you can begin to add client systems to be installed from the network. For information about how to add client systems, see How to Add Systems to Be Installed From the Network With add_install_client.
For additional information about the setup_install_server and the add_to_install_server commands, see the install_scripts(1M) man page.
The installation server contains the installation image needed to install systems from the network. You must create an installation server to install the Solaris software on a system from the network. You do not always need to set up a boot server. Refer to the following guidelines to determine whether you need to set up a separate boot server.
If you are using DHCP to set installation parameters, or if your installation server and client are on the same subnet, you do not need a boot server. See Chapter 16, Configuring and Administering the DHCP Client, in System Administration Guide: IP Services.
The system must include a DVD-ROM drive and be part of the site's network and name service. If you do not use a name service, you must distribute information about this system by following your site's policies.
Insert the Solaris Software DVD into the system's drive.
Create a directory to contain the boot image.
install-dir-path – Specifies the directory where the DVD image is to be copied.
where cdrom0 is the path to the drive that contains the Solaris OS DVD media.
Copy the disc in the drive to the installation server's disk.
install-dir-path – Specifies the directory where the DVD image is to be copied,
The setup_install_server command indicates whether you have enough disk space available for the Solaris software disc image. To determine available disk space, use the df -kl command.
install-dir-path – Specifies the installation image where the DVD image was copied.
Make the installation server available to the boot server by adding this entry to the /etc/dfs/dfstab file.
# shareall |
# cd / |
If the installation server is not on the same subnet as the system to be installed or you are not using DHCP, you need to create a boot server. For more information, see To Create a Boot Server on a Subnet With a DVD Image in Solaris 10 Installation Guide: Network-Based Installations.
After you set up the installation server, you must add the client as an installation client. For information about installing client systems over the network, see How to Add Systems to Be Installed From the Network With add_install_client.
Task |
Description |
For Instructions |
Create a sysidcfg file. |
Create a unique sysidcfg file for every system that requires different configuration information. Note that sample files are available to use. | |
Create a profile for networked systems. |
When setting up a hands off installation for systems on the network, you need to create a directory on a server that is called a JumpStart directory. This directory can be created on the installation server. The JumpStart directory contains system configuration information that is required to complete a hands off installation of the Solaris software. |
How to Create a JumpStart Directory on a Server |
Create a rules file. |
Create the rules file for each group of systems on which you want to install the Solaris OS. Each rule distinguishes a group of systems that are based on one or more system attributes. Each rule also links each group to a profile. A profile is a text file that defines how the Solaris software is to be installed on each system in the group | |
Use the add_install_client command to set up each system you want to install from the network. Each system you want to install needs to find the installation server, the boot server if required, and configuration information about the network. Note that the procedure for adding systems to be installed from the network is the same for both CD and DVD media. |
How to Add Systems to Be Installed From the Network With add_install_client |
The tasks in the preceding table must be completed before installing the Solaris OS on the client systems. Preconfiguration can help you avoid being prompted by the system for this information when installing the Solaris OS. Information that is provided is specific to creating a sysidcfg file for a Solaris OS installation on IBM BladeCenter servers. For complete syntax rules and information about creating a sysidcfg file in other Solaris OS installation situations, refer to the full set of Solaris OS installation documentation at http://docs.sun.com.
You can specify a set of keywords in the sysidcfg file to preconfigure a system.
You must create a unique sysidcfg file for every system that requires different configuration information. You can use the same sysidcfg file to preconfigure the time zone on a set of systems if you want all the systems to be assigned the same time zone. However, if you want to preconfigure a different root (superuser) password for each of those systems, you need to create a unique sysidcfg file for each system.
You can place the sysidcfg file in one of the following:
A UFS or PCFS diskette – Place the sysidcfg file in the root (/) directory on the diskette.
A HTTP or HTTPS server – If you want to perform a wide area network (WAN) boot installation, place the sysidcfg file in the document root directory of the web server.
You can place only one sysidcfg file in a directory or on a diskette. If you are creating more than one sysidcfg file, you must place each file in a different directory or on a different diskette.
The following sections describe the components of the sysidcfg file. Refer to this information when creating a new sysidcfg file. A sample of the sysidcfg file is located in the /install-dir-path/Solaris_10.1/Tools directory. Instead of creating a new file, you can copy this file to use and customize for your installation environment.
You can use two types of keywords in the sysidcfg file: independent and dependent. Dependent keywords are guaranteed to be unique only within independent keywords. A dependent keyword exists only when it is identified with its associated independent keyword.
Syntax Rule |
Example |
Independent keywords can be listed in any order. |
Keywords are not case-sensitive. |
Enclose all dependent keywords in braces ({}) to tie them to their associated independent keyword. |
You can optionally enclose values in single (`) or double quotation marks (“). |
The following table lists the keywords that you can use to configure system information in the sysidcfg file.
Table 1–3 sysidcfg Configuration Information and Keyword Examples|
Configuration Information |
Keyword |
Network interface, host name, Internet Protocol (IP) address, netmask, DHCP, IPv6 |
network_interface |
root (superuser) password |
root_password |
Security policy |
security_policy |
Language in which to display the installation program and desktop |
system_locale |
Terminal type |
terminal |
Time zone |
timezone |
Date and time |
timeserver |
Monitor type |
monitor |
Keyboard language, keyboard layout |
keyboard |
Graphics card, screen size, color depth, display resolution |
display |
Pointing device, number of buttons, IRQ level |
pointer |
The following sections describe the keywords that you can use in the sysidcfg file.
Use the network_interface keyword to perform the following tasks:
Specify a host name.
Specify an IP address.
Specify a netmask value.
Use DHCP to configure the network interface.
Enable IPv6 on the network interface.
The following sections describe how to use the network_interface keyword to configure system interfaces.
To turn off networking for a system, set the network_interface value to none. For example:
network_interface=none |
You can use the network_interface keyword to configure a single interface in the following ways.
With DHCP – You can use a DHCP server on your network to configure the network interface. For more information about how to use a DHCP server during your installation, see Preconfiguring System Configuration Information With the DHCP Service (Task Map).
To use the DHCP server to configure a single interface on the system, use the following syntax for the network_interface keyword:
network_interface=PRIMARY or value
{dhcp protocol_ipv6=yes-or-no}
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is nonnetworked.
Do not use the PRIMARY keyword value if you want to configure multiple interfaces.
Instructs the installation program to configure a specific interface, such as hme0 or eri1.
Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure a single interface on the system without using DHCP, use the following syntax:
{hostname=host-name
default_route=ip-address
ip_address=ip-address
netmask=netmask
Instructs the installation program to configure the first up, non-loopback interface that is found on the system. The order is the same as the order that is displayed with the ifconfig command. If no interfaces are up, then the first non-loopback interface is used. If no non-loopback interfaces are found, then the system is notnetworked.
(Optional) Specifies the host name of the system.
(Optional) Specifies the IP address of the default router. If you want the installation program to detect the router by using the ICMP router discovery protocol, omit this keyword.
If the installation program cannot detect the router, you are prompted for the router information during the installation.
(Optional) Specifies the IP address of the system.
(Optional) Specifies the netmask value for the system.
(Optional) Instructs the installation program either to configure the system to either use IPv6 or to not use IPv6.
To perform an unattended custom JumpStart installation, you must specify a value for the protocol_ipv6 keyword.
Include any combination or none of the hostname, ip_address, and netmask keywords, as needed. If you do not use any of these keywords, omit the braces ({}).
The following example shows how to instruct the installation program to DHCP to configure the eri0 network interface. IPv6 support is not enabled.
network_interface=eri0 {dhcp protocol_ipv6=no}
The following example shows how to configure the eri0 interface with the following settings:
The host name is set to host1.
The IP address is set to 172.31.88.100.
The netmask is set to 255.255.255.0.
IPv6 support is not enabled on the interface.
network_interface=eri0 {hostname=host1 ip_address=172.31.88.100
netmask=255.255.255.0 protocol_ipv6=no}
You can configure multiple network interfaces in your sysidcfg file. For each interface that you want to configure, include a network_interface keyword entry in the sysidcfg file.
You can use the network_interface keyword to configure multiple interfaces in the following ways:
To use the DHCP server to configure a network interface on the system, use the following syntax for the network_interface keyword.
network_interface=value {PRIMARY
(Optional) Specifies value as the primary interface.
Instructs the installation program to configure the system either to use IPv6 or to not use IPv6.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure multiple interfaces without using DHCP, use the following syntax.
network_interface=value {PRIMARY hostname=host-name
default_route=ip-address or NONE
netmask=netmask
If you configure multiple interfaces in the sysidcfg file, set default_route=NONE for each secondary interface that does not use a static default route.
If the installation program cannot detect the router, you are prompted for the router information during installation.
(Optional) Instructs the installation program to configure the system either to use IPv6 or to not use IPv6.
In the same sysidcfg file, you can use DHCP to configure certain interfaces, while also specifying the configuration information for other interfaces in the sysidcfg file.
In the following example, the network interfaces eri0 and eri1 are configured in the following way:
eri0 is configured by using the DHCP server. IPv6 support is not enabled on eri0.
eri1 is the primary network interface. The host name is set to host1, and the IP address is set to 172.31.88.100. The netmask is set to 255.255.255.0. IPv6 support is not enabled on eri1.
network_interface=eri1 {primary hostname=host1
protocol_ipv6=no}
You can specify the root (superuser) password to the system in the sysidcfg file. To specify the root (superuser) password, use the root_password keyword with the following syntax:
root_password=encrypted-password |
encrypted-password is the encrypted password as it appears in the /etc/shadow file.
You can use the security_policy keyword in your sysidcfg file to configure your system to use the Kerberos network authentication protocol. If you want to configure the system to use Kerberos, use the following syntax:
security_policy=kerberos {default_realm=FQDN
admin_server=FQDN kdc=FQDN1, FQDN2, FQDN3}
FQDN specifies the fully qualified domain name of the Kerberos default realm, the administration server, and key distribution center (KDC). You must specify at least one, but no more than three, key distribution centers.
If you do not want to set the security policy for the system, set security_policy=NONE.
For more information about the Kerberos network authentication protocol, see Part VI, Kerberos Service, in System Administration Guide: Security Services.
The following example configures the system to use Kerberos with the following information:
The Kerberos default realm is example.COM.
The Kerberos administration server is krbadmin.example.COM.
The two key distribution centers are kdc1.example.COM and kdc2.example.COM.
{default_realm=example.COM
admin_server=krbadmin.example.COM
kdc=kdc1.example.COM,
kdc2.example.COM}
You can use the system_locale keyword to specify the language in which to display the installation program and desktop. Use the following syntax to specify a locale:
system_locale=locale |
locale specifies the language that you want the system to use to display the installation panels and screens. For a list of valid locale values, see the /usr/lib/locale directory or the International Language Environments Guide.
You can use the terminal keyword to specify the terminal type for the system. Use the following syntax to specify the terminal type:
terminal=terminal_type |
terminal_type specifies the terminal type for the system. For a list of valid terminal types, see the subdirectories in the /usr/share/lib/terminfo directory.
You can set the time zone for the system with the timezone keyword. Use the following syntax:
timezone=timezone |
The timezone keyword specifies the time zone value for the system. The directories and files in the /usr/share/lib/zoneinfo directory provide the valid time zone values. The timezone value is the name of the path relative to the /usr/share/lib/zoneinfo directory. You can also specify any valid Olson time zone.
In the following example, the system time zone is set to mountain standard time in the United States.
timezone=US/Mountain |
The installation program configures the system to use the time zone information in /usr/share/lib/zoneinfo/US/Mountain.
You can use the timeserver keyword to specify the system that sets the date and time on the system you want to install.
Do not set timeserver=host-name or ip-address if you are running a name service.
Choose one of the following methods to set the timeserver keyword:
To configure the system to serve as its own time server, set timeserver=localhost. If you specify localhost as the time server, the system's time is assumed to be correct.
To specify another system as the time server, specify either the host name or the IP address of the time server with the timeserver keyword. Use the following syntax:
timeserver=host-name or ip-address |
where host-name is the host name of the time server system, and ip-address specifies the IP address of the time server.
You can configure monitor information with the monitor keyword. Use the following syntax with the monitor keyword:
monitor=monitor-type |
To set the value for the monitor keyword, run the kdmconfig -d command on the system that you want to install. Copy the line of output that includes the monitor keyword, and include this line in the sysidcfg file.
You can configure the keyboard language and layout information with the keyboard keyword. Use the following syntax with the keyboard keyword:
keyboard=keyboard-language {layout=value}
To set the value for the keyboard keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the keyboard keyword, and include this line in the sysidcfg file.
You can configure the following information with the display keyword:
Graphics card
Screen size
Color depth
Display resolution
Use the following syntax with the display keyword:
display=graphics_card {size=screen_size
depth=color_depth
resolution=screen_resolution}
To set the appropriate values for the display keyword, run the kdmconfig -d command on the system you want to install. Copy the line of output that includes the display keyword, and include this line in the sysidcfg file.
You can configure the following mouse information with the pointer keyword:
Pointing device
Number of buttons
IRQ level
Use the following syntax with the pointer keyword:
pointer=pointing-device {nbuttons=number-buttons irq=value}
To set the value for the pointer keyword, run the kdmconfig -d command on the system that you want to install. Copy the line of output that includes the pointer keyword, and include this line in the sysidcfg file.
For more information about all of these keywords, see the kdmconfig(1M) man page.
The Solaris OS installation programs require you to provide configuration information about a system, such as peripheral devices, host name, IP address, and name service (if applicable). Before the installation tools prompt you for this configuration information, the tools check for this information in the sysidcfg file and then in the name services databases (if applicable). When the Solaris installation program or the custom JumpStart installation program detects preconfigured system information in the sysidcfg file, you are not prompted to enter this information manually, which saves on time and resources. For example, if you have several systems, and you do not want a time zone prompt displayed every time you install the Solaris OS, you can specify the time zone in the sysidcfg file.
For more information about the sysidcfg file, see the sysidcfg(4) man page.
Using a text editor, create a file named sysidcfg.
Type the keywords that you want to include in the sysidcfg configuration file. See Preconfiguring With the sysidcfg File for guidelines and syntax to use.
Save the sysidcfg file.
If you create more than one sysidcfg file, you must save each file in a separate directory or on a separate diskette.
Make the sysidcfg file available to clients through either of the following:
A shared NFS file system. Use the add_install_client command with the -p option to set up the system to install from the network.
The root (/) directory on a UFS diskette or PCFS diskette.
The following example shows a sysidcfg file for a group of systems that use the same type of keyboard, graphics cards, and pointing devices information. If the sysidcfg file in this example were used, you would be prompted to select a language (system_locale) before the installation could proceed.
The device information (keyboard, display, and pointer) was obtained by running the kdmconfig command with the -d option. See the kdmconfig(1M) man page for more information.
keyboard=ATKBD {layout=US-English}
display=ati {size=15-inch}
pointer=MS-S
timezone=US/Central
timeserver=timehost1
terminal=ibm-pc
name_service=NIS {domain_name=marquee.central.example.com
name_server=nmsvr2(172.25.112.3)}
root_password=URFUni9
If you plan to use the sysidcfg file in an installation over the network, you need to set up an installation server and add the system as an installation client. For more information, see Preparing to Install the Solaris Operating System on IBM BladeCenter Servers (Task Map) and Preconfiguring With the sysidcfg File.
If you plan to use the sysidcfg file in a custom JumpStart installation, you need to create a profile and a rules.ok file. See How To Create a rules File.
When setting up custom JumpStart installations for systems on the network, you need to create a directory on a server that is called a JumpStart directory. The JumpStart directory contains all of the essential custom JumpStart files, for example, the rules file, rules.ok file, and profiles. You must save the JumpStart directory in the root (/) directory of the profile server.
The server that contains a JumpStart directory is called a profile server. A profile server can be the same system as an installation server or a boot server. The profile server can be also be a separate server. The profile server can provide custom JumpStart files for different platforms.
After you create a profile server, you must enable all systems access to the server. For detailed instructions, see How to Enable All Systems to Access the Profile Server.
The JumpStart directory contains all of the essential custom JumpStart files, for example, the rules file, the rules.ok file, and profiles. You must save the JumpStart directory in the root (/) directory of the profile server.
This procedure assumes that the system is running Solaris Volume Manager. If you are not using Solaris Volume Manager to manage discs, refer to System Administration Guide: Devices and File Systems for detailed information about managing removable media without Solaris Volume Manager.
On the server on which you want to create the JumpStart directory, log in as superuser.
Create the JumpStart directory anywhere on the server.
# mkdir -m 755 jumpstart-dir-path |
where jumpstart-dir-path is the absolute path of the JumpStart directory.
For example, the following command creates a directory that is called jumpstart in the root (/) directory and sets the permissions to 755:
# mkdir -m 755 /jumpstart |
Edit the /etc/dfs/dfstab file by adding the following entry:
share -F nfs -o ro,anon=0 jumpstart-dir-path |
For example, the following entry shares the /jumpstart directory:
share -F nfs -o ro,anon=0 /jumpstart |
Share the JumpStart directory by typing shareall. Press Enter.
Determine if you want to copy examples of custom JumpStart files to your JumpStart directory.
If no, go to Step 8.
If yes, depending on the type of software media you are using, do one of the following:
At least the Solaris 10 1/06 Operating System DVD or the Solaris 10 1/06 Software – 1 CD
Insert the CD into the server's CD-ROM drive.
Solaris Volume Manager automatically mounts the CD.
Image of at least the Solaris 10 1/06 Operating System DVD or the Solaris 10 1/06 Software – 1 CD
Change directory to the location of the Solaris Operating System DVD or the Solaris Software – 1 image.
For example, type:
# cd /export/install |
Copy the sample custom JumpStart files into the JumpStart directory on the profile server.
# cp -r media-path/Solaris_Solaris_10.1/Misc/jumpstart_sample/* jumpstart-dir-path |
The path to the CD, DVD, or image on the local disk.
The path on the profile server where you are placing the sample custom JumpStart files.
For example, the following command copies the jumpstart_sample directory into the /jumpstart directory on the profile server:
cp -r /cdrom/cdrom0/s0/Solaris_Solariss_10.1/Misc/jumpstart_sample/* /jumpstart |
Update the sample JumpStart files so that the files work in your environment.
Ensure that root owns the JumpStart directory and that the permissions are set to 755.
Allow systems on the network access to the profile server.
When you create a profile server, you must ensure that systems can access the JumpStart directory on the profile server during a custom JumpStart installation. Use one of the following ways to enable access.
Use the add_install_client command.
Each time that you add a system for network installation, use the -c option with the add_install_client command to specify the profile server.
If you are not using NFS, then you must edit the boot entry on the GRUB menu to enable all systems to access the profile server.
For instructions, see How to Add Systems to Be Installed From the Network With add_install_client.
Edit the boot entry in the GRUB menu.
Specify the location of the JumpStart directory on the profile server when you boot the system by editing the boot entry on the GRUB menu. You must compress the custom JumpStart configuration files into one file. Then, save the compressed configuration file on an NFS server, an HTTP server, or on media that the system can access locally. Note that when you edit the GRUB menu entry, you must specify the location of the compressed file.
For instructions, see To Create a Compressed Configuration File in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations and Performing a Custom JumpStart Installation by Editing the GRUB boot Command in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
Add a wildcard in the /etc/bootparams file.
For instructions, see How to Enable All Systems to Access the Profile Server.
Use this procedure only if you store network installation information in the /etc/bootparams file.
To use this procedure, all systems must be of the same type, such as all x86 based systems.
Do not use this procedure under the following conditions:
If you save the JumpStart directory on a diskette.
If you specify the location of the profile server when you boot the system.
If you have systems of different architectures, you must specify the location of the profile server when you boot the system.
You can also store network installation information about a DHCP server.
Use the add_install_client command and the -d option to instruct the custom JumpStart program to use the DHCP server with PXE. In this Solaris release, you can also add the dhcp option by editing the boot entry in the GRUB menu when you boot the system.
For step-by-step instructions on editing the GRUB menu, see Performing a GRUB Based Installation From the Network in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations and How to Modify the Solaris Boot Behavior by Editing the GRUB Menu in System Administration Guide: Basic Administration.
On the installation or boot server, log in as superuser.
Using a text editor, open the /etc/bootparams file.
* install_config=server:jumpstart-dir-path |
A wildcard character that specifies that all systems have access
The host name of the profile server where the JumpStart directory is located
The absolute path of the JumpStart directory
For example, the following entry allows all systems to access the /jumpstart directory on the profile server that is named sherlock:
* install_config=sherlock:/jumpstart |
All systems can now access the profile server.
Use of this procedure might produce the following error message when an installation client is booted:
WARNING: getfile: RPC failed: error 5: (RPC Timed out).
See Booting From the Network, Error Messages in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations for details about this error message.
A profile is a text file that defines how to install the Solaris software on a system. A profile defines the elements of an installation, for example, which software group to install. Every rule specifies a profile that defines how a system is to be installed. You can create different profiles for every rule. You can also use the same profile in more than one rule. See Creating the rules File.
A profile consists of one or more profile keywords and their values. Each profile keyword is a command that controls one aspect of how the JumpStart program is to install the Solaris software on a system. For example, the following profile keyword and value specify that the JumpStart program install the system as a server:
system_type server |
Sample profiles are already located in the JumpStart directory, if you created the JumpStart directory by using the procedure, Creating a Profile Server for Networked Systems.
A profile must contain the following:
One keyword per line
The root_device keyword if the systems that are being upgraded by the profile contain more than one root (/) file system that can be upgraded
A profile can contain the following:
Commented text
Any text that is included after the # symbol on a line is treated by the JumpStart program as commented text. If a line begins with the # symbol, the entire line is treated as a comment.
One or more blank lines
Using a text editor, create a text file. Name the file descriptively. Or, open a sample profile in the JumpStart directory that you created.
Ensure that the name of the profile reflects how you intend to use the profile to install the Solaris software on a system. For example, you might name the profiles basic_install, eng_profile, or user_profile.
Add profile keywords and values to the profile.
See Profile Examples.
Profile keywords and their values are case-sensitive.
Save the profile in the JumpStart directory.
Ensure that root owns the profile and that the permissions are set to 644.
(Optional) Test the profile.
The following examples of profiles show how to use different profile keywords and profile values to control how the Solaris software is installed on a system. Profile keywords and values contains a description of profile keywords and values.
# profile keywords profile values # ---------------- ------------------- install_type initial_install system_type standalone partitioning explicit filesys c0t0d0s0 auto / filesys c0t3d0s1 auto swap filesys any auto usr cluster SUNWCall |
The following describes some of the keywords and values from this example:
The file system slices are determined by the filesys keywords that are value explicit. The size of the root (/) directory is based on the selected software, value auto, and is installed on c0t0d0s0. The size of swap is set to the necessary size and is installed on c0t3d0s1. usr is based on the selected software and the installation program determines where usr is installed, based on the value any.
The Entire Solaris Software Group, SUNWCall, is installed on the system.
# profile keywords profile values # ---------------- ------------------- install_type initial_install system_type standalone fdisk c0t0d0 0x04 delete fdisk c0t0d0 solaris maxfree cluster SUNWCall cluster SUNWCacc delete |
All fdisk partitions of type DOSOS16 (04 hexadecimal) are deleted from the c0t0d0 disk.
A Solaris fdisk partition is created on the largest contiguous free space on the c0t0d0 disk.
The system accounting utilities, SUNWCacc, are not to be installed on the system.
After you create a profile, use the pfinstallcommand to test the profile. Test the profile before installing or upgrading a system. Testing a profile is especially useful when you are creating upgrade profiles that reallocate disk space.
Review the installation output that is generated by pfinstall to determine if the profile works as you intended. For example, use the profile to determine if a system has enough disk space for installing a new release of the Solaris software before you perform the installation on that system.
The pfinstall command enables you to test a profile against the following:
The system's disk configuration where pfinstall is being run.
Other disk configurations. You use a disk configuration file that represents a structure of a disk, for example, a disk's bytes/sector, flags, and slices.
You cannot use a disk configuration file to test a profile you intend to use for installing a system. Instead, you must test the profile against the system's actual disk configuration and the software that is currently installed on that system.
Locate a system on which to test the profile.
Test an initial installation profile on a system that is running at least the Solaris 10 1/06 software.
Become superuser or assume an equivalent role.
Create a temporary mount point.
# mkdir /tmp/mnt |
Mount the directory that contains the profile or profiles that you want to test. Type the instructions that apply.
To test the profile with a specific system memory size, set SYS_MEMSIZE to the specific memory size in MB.
# SYS_MEMSIZE=memory-size # export SYS_MEMSIZE |
Depending on whether you mounted a directory in Step 4, do one of the following:
Test the profile.
# /usr/sbin/install.d/pfinstall -D:-d disk-config-file -c path profile |
You must include the -d option or the -D option when using the pfinstall command. If you do not include one of these options, the command uses the profile you that specify for installing the Solaris software. As a result, all of the system data is overwritten.
pfinstall uses the current system's disk configuration to test the profile.
pfinstall uses the disk configuration file, disk-config-file, to test the profile. If disk-config-file is not located in the directory where pfinstall is run, you must specify the path.
You cannot use the -d disk-config-file option with an upgrade profile, install_type upgrade. You must always test an upgrade profile against a system's disk configuration, that is, you must use the -D option.
The path to the Solaris software image. You use this option, for example, if the system is using Solaris Volume Manager to mount the Solaris Software - 1 CD for your platform.
The -c option is not required if you booted from at least the Solaris 10 1/06 DVD or the Solaris 10 1/06 Software - 1 CD image for your platform. The DVD or CD image is mounted on /cdrom as part of the booting process.
The name of the profile to test. If profile is not in the directory where pfinstall is being run, you must specify the path.
The following example shows how to use pfinstall to test a profile that is named basic_prof. The profile is tested against the disk configuration on a system on which the Solaris software is installed. The basic_prof profile is located in the /jumpstart directory, and the path to the Solaris 10 1/06 Software for x86 Platforms - 1 CD image is specified because Solaris Volume Manager is being used.
# cd /jumpstart # /usr/sbin/install.d/pfinstall -D -c /cdrom/path-name basic_prof |
The following example shows how to use pfinstall to test the profile that is named basic_prof on a Solaris 10 1/06 system. The test is performed against the 535_test disk configuration file. The test checks for 64 MB of system memory. This example uses a Solaris 10 1/06 Software for x86 Platforms - 1 CD image that is located in the /export/install directory.
# SYS_MEMSIZE=64 # export SYS_MEMSIZE # /usr/sbin/install.d/pfinstall -d 535_test -c /export/install basic_prof |
The rules file is a text file that contains rules for each group of systems on which you want to install the Solaris OS. Each rule distinguishes a group of systems that are based on one or more system attributes. Each rule also links each group to a profile. A profile is a text file that defines how the Solaris software is to be installed on each system in the group. For example, the following rule specifies that the JumpStart program use the information in the basic_prof profile for installing any system with the sun4u platform group:
karch sun4u - basic_prof - |
The rules file is used to create the rules.ok file, which is required for custom JumpStart installations.
If you set up the JumpStart directory by using the procedures in Creating a Profile Server for Networked Systems, a sample rules file is already located in the JumpStart directory. The sample rules file contains documentation and some sample rules. If you use the sample rules file, make sure you comment out the sample rules that you do not intend to use.
The rules file must have the following attributes:
The rules file can contain any of the following:
Commented text
Any text that is included after the # symbol on a line is treated by JumpStart as commented text. If a line begins with the # symbol, the entire line is treated as a comment.
One or more multiline rules
To continue a single rule onto a new line, include a backslash character (\) just before pressing Return.
A rule within a rules file must adhere to the following syntax:
!rule-keyword rule-value && !rule-keyword rule-value ... begin profile finish |
A symbol that is used before a keyword to indicate negation.
A predefined lexical unit or word that describes a general system attribute, such as host name, hostname, or memory size, memsize. rule-keyword is used with the rule value to match a system with the same attribute to a profile.
A value that provides the specific system attribute for the corresponding rule-keyword. Rule values are described in the section, Rule Keywords and Values in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
A symbol you must use to join rule-keyword and rule-value pairs in the same rule (a logical AND). During a custom JumpStart installation, a system must match every pair in the rule before the rule matches.
The name of an optional Bourne shell script that can be executed before the installation begins. If no begin script exists, you must type a minus sign (-) in this field. All begin scripts must be located in the JumpStart directory.
Information about how to create begin scripts is presented in Creating Begin Scripts in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
The name of a text file that defines how the Solaris software is to be installed on the system when a system matches the rule. The information in a profile consists of profile keywords and their corresponding profile values. All profiles must be located in the JumpStart directory.
The name of an optional Bourne shell script that can be executed after the installation is completed. If no finish script exists, you must type a minus sign (-) in this field. All finish scripts must be located in the JumpStart directory.
Information about how to create finish scripts is presented in Creating Finish Scripts in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
At the minimum, each rule must contain the following:
A keyword, a value, and a corresponding profile
A minus sign (-) in the begin and finish fields if no begin or finish scripts are specified
Use a text editor to create a text file that is named rules. Or, open the sample rules file in the JumpStart directory that you created.
Add a rule in the rules file for each group of systems on which you want to install the Solaris software.
For an example of some rules file keywords and values, see rules File Example. For a complete list of the rules file keywords and values, see Rule Keywords and Values in Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations.
Save the rules file in the JumpStart directory.
Ensure that root owns the rules file and that the permissions are set to 644.
The following shows example rules in a rules file. Each line has a rule keyword and a valid value for that keyword.
The JumpStart program scans the rules file from top to bottom. When the JumpStart program matches a rule keyword and value with a known system, the JumpStart program installs the Solaris software that is specified by the profile listed in the profile field.
# rule keywords and rule values begin script profile finish script # ----------------------------- ------------ -------- ------------- hostname eng-1 - basic_prof - network 192.168.255.255 && !model \ 'SUNW,Sun-Blade-100' - net_prof - model SUNW,SPARCstation-LX - lx_prof complete network 192.168.2.0 && karch i86pc setup x86_prof done memsize 64-128 && arch i386 - prog_prof - any - - generic_prof - |
The following describes some of the keywords and values from this example.
The rule matches if the system's host name is eng-1. The basic_prof profile is used for installing the Solaris software on systems that match the rule.
The rule matches if the system is on subnet 192.168.255.255, and if the system is not a Sun BladeTM 100 (SUNW,Sun-Blade-100). The net_prof profile is used for installing the Solaris software on systems that match this rule.
The rule matches if the system is a SPARCstation® LX. The lx_prof profile and the complete finish script are used to install the Solaris software on systems that match this rule.
The rule matches if the system is on subnet 192.168.2.0 and is an x86 based sun4u system. The setup begin script, the x864u_prof profile, and the done finish script are used for installing the Solaris software on systems that match the rule.
The rule matches if the system has between 64 and 128 MB of memory and is an x86 based system. The prog_prof profile is used for installing the Solaris software on systems that match this rule.
The rule matches any system that did not match the preceding rules. The generic_prof profile is used for installing the Solaris software on systems that match this rule. If any is used, it should always be the last rule in the rules file.
Before you can use a profile and rules file, you must run the check script to validate that the files are set up correctly. If all rules and profiles are correctly set up, the rules.ok file is created. This file is required by the custom JumpStart installation software to match a system to a profile.
The following table describes what the check script does.
Table 1–4 check Script Functions
The check script is in the Solaris_Solaris_version/Misc/jumpstart_sample directory on the Solaris Software DVD or the Solaris Software 1 – CD.
Ensure that the check script is located in the JumpStart directory.
The check script is in the Solaris_Solaris_version/Misc/jumpstart_sample directory on the Solaris 10 Software DVD or on the Solaris Software - 1 CD.
Run the check script to validate the rules file.
$ ./check -p path -r filename |
Validates the rules by using the check script from the Solaris 10 software image instead of the check script from the system you are using. path is the image on a local disk or a mounted on the Solaris DVD or a Solaris Software - 1 CD.
Use this option to run the most recent version of check if your system is running a previous version of Solaris.
Specifies a rules file other than the file that is named rules. Using this option, you can test the validity of a rule before you integrate the rule into the rules file.
As the check script runs, the script reports on the validity of the rules file and each profile. If no errors are reported, the script generates the following:
The custom JumpStart configuration is ok |
Ensure that root owns the rules.ok file and that the permissions are set to 644.
After you create an install server and, if necessary, a boot server, you must set up each system that you want to install from the network. Use the following procedure to set up a client system to install from the network with the add_install_client command.
For more options to use with this command, see the add_install_client(1M) man page.
If you have a boot server, make sure that you have shared the installation server installation image and have started the appropriate services. See How to Create an Installation Server With x86 CD Media or How to Create an Installation Server With x86 DVD Media.
Each system that you want to install needs to find the following:
Installation server
Boot server, if it is required
The sysidcfg file, if you use a sysidcfg file to preconfigure system information
The profile in the JumpStart directory on the profile server, if you are using the custom JumpStart installation method
On the installation server or boot server, become superuser or assume an equivalent role.
Change to the Tools directory on the Solaris DVD image.
# cd /install-dir-path/Solaris_10/Tools |
Specifies the path to the Tools directory
Set up the client system so that it can be installed from the network.
# ./add_install_client -d -s install-server:install-dir_path -c jumpstart-server:jumpstart-dir-path -p sysid-server:path -t boot-image-path -b "boot-property=value" -e ethernet-address client-name platform-group |
Specifies that the client is to use DHCP to obtain the network installation parameters. If you use the -d only, the add_install_client command sets up the installation information for client systems of the same class, for example, all x86 based client machines. To set up the installation information for a specific client, use -d with the -e option.
Use this option to boot the systems from the network by using a PXE network boot. The output of this option lists the DHCP options that you need to create on the DHCP server.
For more information about class-specific installations that use DHCP, see Creating DHCP Options and Macros for Solaris Installation Parameters.
Specifies the name and path to the installation server.
where install-server is the host name of the installation server and install-dir-path is the absolute path to the Solaris DVD or CD image.
Specifies a JumpStart directory for custom JumpStart installations. jumpstart-server is the host name of the server on which the JumpStart directory is located. The jumpstart-dir-path is the absolute path to the JumpStart directory.
Specifies the path to the sysidcfg file for preconfiguring system information. sysid-server is either a valid host name or an IP address for the server that contains the file. path is the absolute path to the directory containing the sysidcfg file.
Specifies the path to an alternate boot image if you want to use a boot image other than the image in the Tools directory on the Solaris OS net installation image, CD, or DVD.
Enables you to set the value of a boot property variable that you want to use to boot the client from the network. The -b option must be used with the -e option.
See the eeprom(1M) man page for descriptions of boot properties.
Specifies the Ethernet address of the client that you want to install. This option enables you to set up the installation information to use for a specific client, including a boot file for that client. For instance, if you specify -e 00:07:e9:04:4a:bf for a client, the command creates the boot file 010007E9044ABF.i86pc in the /tftpboot directory.
In previous releases, the -e option created a boot file with the prefix nbp.. Starting with the Solaris 10 1/06 release, the nbp. prefix is not used in boot file names. However, starting with the Solaris 10 1/06 release, the use of legacy boot files with the nbp. prefix is supported.
For more information about client-specific installations by using DHCP, see Creating DHCP Options and Macros for Solaris Installation Parameters.
Is the name of the system to be installed from the network. This name is not the host name of the installation server.
Is the platform group of the system to be installed.
The following example illustrates how to add an installation client to an installation server when you are using DHCP to set installation parameters on the network. The -d option is used to specify that clients use the DHCP protocol for configuration. To perform a PXE network boot, you must use the DHCP protocol. The -s option is used to specify that the clients are to be installed from the installation server that is named rosemary. This server contains a Solaris 10 1/06 DVD image in /export/home/dvdx86.
# cd /export/boot/dvdx86/Solaris_10/Tools # ./add_install_client -d -s rosemary:/export/home/dvdx86 i86pc |
The following example illustrates how to add an installation client to an installation server when you are using DHCP to set installation parameters on the network. The -d option is used to specify that clients are to use the DHCP protocol for configuration. You must use the DHCP protocol to perform a PXE network boot. The -e option indicates that this installation occur only on the client with the Ethernet address 00:07:e9:04:4a:bf . The -s option is used to specify that the clients are to be installed from the installation server that is named rosemary. This server contains a image in /export/home/dvdx86.
# cd /export/boot/dvdx86/Solaris_10/Tools # ./add_install_client -d -e 00:07:e9:04:4a:bf -s rosemary:/export/home/dvdx86 i86pc |
These commands set up the client with the Ethernet address 00:07:e9:04:4a:bf as an installation client. The boot file 010007E9044ABF.i86pc is created on the installation server. In previous releases, this boot file was named nbp.010007E9044ABF.i86pc.
The following example illustrates how to add an install client to an installation server and specify a serial console to use during the installation. This example sets up the install client in the following manner.
The -d option indicates that the client is set up to use DHCP to set installation parameters.
The -e option indicates that this installation will occur only on the client with the Ethernet address 00:07:e9:04:4a:bf.
The -b option instructs the installation program to use the serial port ttya as an input and as an output device.
# cd /export/boot/dvdx86/Solaris_10/Tools # ./add_install_client -d -e 00:07:e9:04:4a:bf -b "console=ttya" i86pc |
For a complete description of the boot property variables and values that you can use with the -b option, see the eeprom(1M) man page.
For information about setting up a serial over LAN (SOL) connection after installing the Solaris OS, see How to Set Up a Serial Over LAN Connection. The SOL connection is used to manage systems remotely.
If you are using a DHCP server to install the client over the network, configure the DHCP server and create the options and macros that are listed in the output of the add_install_client -d command. For instructions on how to configure a DHCP server to support network installations, see Preconfiguring System Configuration Information With the DHCP Service (Task Map).
If you are not using a DHCP server, you must boot the system from a local Solaris OS DVD or CD.
For additional information about the add_install_client command, see the install_scripts(1M) man page.
Task |
Description |
For Instructions |
Configure the DHCP server. This task is optional. Note – If you want to install a system from the network with PXE, you must configure a DHCP server. |
If you want to use DHCP to provide system configuration and installation parameters, configure the DHCP server, then create the appropriate options and macros for your installation. |
Chapter 13, Planning for DHCP Service (Tasks), in System Administration Guide: IP Services and Chapter 14, Configuring the DHCP Service (Tasks), in System Administration Guide: IP Services. |
Write a script that creates DHCP options and macros to support a Solaris installation by using the dhtadm command. |
To install DHCP clients with a DHCP server over the network, you can create a script that uses the dhtadm command. The DHCP options and macros that you create by running this script are used to pass information that is needed for installing the Solaris OS. |
Writing a Script That Uses dhtadm to Create Options and Macros |
Use DHCP Manager to create DHCP options and macros to support a Solaris installation. |
To install DHCP clients with a DHCP server over the network, you can use DHCP Manager to create options and macros. The DHCP options and macros that you create are used to pass information that is needed for installing the Solaris OS. |
How to Create Options to Support a Solaris Installation (DHCP Manager) How to Create Macros to Support a Solaris Installation (DHCP Manager) |
The Dynamic Host Configuration Protocol (DHCP) enables host systems in a TCP/IP network to be configured automatically for the network as they boot. DHCP uses a client and server mechanism. Servers store and manage configuration information for clients, and provide that information as a result of a client's request. The information includes the client's IP address and information about network services that are available to the client.
A primary benefit of DHCP is its ability to manage IP address assignments through leasing. Leasing enables IP addresses to be reclaimed when not in use and reassigned to other clients. This ability enables a site to use a smaller pool of IP addresses than would be needed if all clients were assigned a permanent address.
You can use DHCP for installing the Solaris OS on certain client systems on your network. All systems that meet the hardware requirements for running the Solaris OS can use this feature.
When you add clients with the add_install_client -d script on the installation server, the script reports DHCP configuration information to standard output. This information can be used when you create the options and macros that are needed to pass network installation information to clients. You can create DHCP options and macros in one of the following ways:
For installing DHCP clients with a DHCP server over the network, you must create DHCP options to pass information that is needed for installing the Solaris OS. You can customize the macros in your DHCP service to perform the following types of installations:
You can create these options and macros by using the following methods:
Write a script that creates the options and macros by using the dhtadm command. See Writing a Script That Uses dhtadm to Create Options and Macros.
Create the options and macros with DHCP Manager. See How to Create Options to Support a Solaris Installation (DHCP Manager) and How to Create Macros to Support a Solaris Installation (DHCP Manager).
Class-specific installations – You can instruct the DHCP service to perform a network installation for all clients of a specific class. For example, you can define a DHCP macro that performs the same installation on all Sun Blade systems on the network. Use the output of the add_install_client -d script to set up a class-specific installation.
Network-specific installations – You can instruct the DHCP service to perform a network installation for all clients on a specific network. For example, you can define a DHCP macro that performs the same installation on all systems in the 192.168.2.1 network.
Client-specific installations – You can instruct the DHCP service to perform a network installation for a client with a specific Ethernet address. For example, you can define a DHCP macro that performs a specific installation on the client with the Ethernet address 00:07:e9:04:4a:bf. Use the output of the add_install_client -d -e ethernet-address command to set up a client-specific installation.
For more information about setting up clients to use a DHCP server for a network installation, see Supporting Solaris Network Installation With the DHCP Service in System Administration Guide: IP Services.
For detailed information about DHCP options, see Working With DHCP Options (Task Map) in System Administration Guide: IP Services.
You can use the standard DHCP options that are listed in Table 1–6 to configure and install systems. These options are not platform specific, and can be used for installing the Solaris OS on a variety of x86 based systems. Use these options for installing the Solaris software on systems by using DHCP. For a complete list of standard options, see the dhcp_inittab(4) man page.
Table 1–6 Values for Standard DHCP Options|
Option Name |
Code |
Data Type |
Granularity |
Maximum |
Description |
BootFile |
N/A |
ASCII |
1 |
1 |
Path to the client's boot file |
BootSrvA |
N/A |
IP address |
1 |
1 |
IP address of boot server |
DNSdmain |
15 |
ASCII |
1 |
0 |
DNS domain name |
DNSserv |
6 |
IP address |
1 |
0 |
List of DNS name servers |
NISdmain |
40 |
ASCII |
1 |
0 |
NIS domain name |
NISservs |
41 |
IP address |
1 |
0 |
IP address of NIS server |
NIS+dom |
64 |
ASCII |
1 |
0 |
NIS+ domain name |
NIS+serv |
65 |
IP address |
1 |
0 |
IP address of NIS+ server |
Router |
3 |
IP address |
1 |
0 |
IP addresses of network routers |
When you have created the options, you can create macros that include those options. The following table lists examples of macros that you can create to support a Solaris client installation.
Table 1–7 Example Macros to Support Network Installation Clients|
Macro Name |
Contains These Options and Macros |
Solaris |
SrootIP4, SrootNM,SinstIP4, SinstNM |
i86pc |
Solaris macro, SrootPTH, SinstPTH, SbootFIL |
PXEClient:Arch:00000:UNDI:002001 |
BootSrvA, BootFile |
xxx.xxx.xxx.xxx network address macros |
BootSrvA option could be added to existing network address macros. The value of BootSrvA indicates the tftboot server. |
01client-MAC-address client-specific macros (for example, 010007E9044ABF) |
The macro names in this table match the vendor client classes of the clients that are installed from the network. These names are examples of clients that you might have on your network.
The total size of the vendor options that are provided to a particular client must not exceed 255 bytes, including option codes and length information. This limitation results from the current Solaris DHCP protocol implementation. Generally, you must pass the minimum amount of vendor information needed. Use short path names in options that require path names. If you create symbolic links to long paths, you can use the shorter link names.
You can create a Korn shell script by adapting examples in this section to create all the options that are described and some other useful macros. Be sure to change all IP addresses and values contained in quotation marks to the correct IP addresses, server names, and paths for your network. Also, edit the Vendor= key to indicate the class of clients that you have. Use the information that add_install_client -d reports to obtain the data that you need to adapt the script.
#!/bin/sh ImageDir="/export/home/sol10_18b" JumpStartDir="/export/home/jumpstart" DHCPDir="/export/home/dhcp" DHCPNetwork="192.168.70.0" SrvAdd="192.168.70.35" # Sharing out the Image directory share -F nfs -o ro,anon=0 $ImageDir # Sharing out the jumpstart directory share -F nfs -o ro,anon=0 $JumpStartDir dhcpconfig -D -r SUNWfiles -p $DHCPDir -l 84600 -h files dhcpconfig -N $DHCPNetwork echo "Adding vendor specific symbol table" echo "" dhtadm -A -s SrootIP4 -d 'Vendor=SUNW.i86pc,2,IP,1,1' dhtadm -A -s SrootNM -d 'Vendor=SUNW.i86pc,3,ASCII,1,0' dhtadm -A -s SrootPTH -d 'Vendor=SUNW.i86pc,4,ASCII,1,0' dhtadm -A -s SinstIP4 -d 'Vendor=SUNW.i86pc,10,IP,1,1' dhtadm -A -s SinstNM -d 'Vendor=SUNW.i86pc,11,ASCII,1,0' dhtadm -A -s SinstPTH -d 'Vendor=SUNW.i86pc,12,ASCII,1,0' dhtadm -A -s SsysidCF -d 'Vendor=SUNW.i86pc,13,ASCII,1,0' dhtadm -A -s SjumpsCF -d 'Vendor=SUNW.i86pc,14,ASCII,1,0' dhtadm -A -s SbootURI -d 'Vendor=SUNW.i86pc,16,ASCII,1,0' echo "Adding PXE info" echo "" dhtadm -A -m PXEClient:Arch:00000:UNDI:002001 -d (Command continued on next line) ':BootFile="pxegrub.I86PC.Solaris_10-1":BootSrvA=192.168.70.35:' |
#!/bin/sh echo "Add install client" echo "" cd /export/home/sol10_18b/Solaris_10/Tools ./add_install_client -d -e 0:11:25:9b:9c:98 i86pc echo "Creating client ID and association of macros" echo "" dhtadm -A -m 010011259B9C98 -d ':SinstPTH="/export/home/sol10_18b":' dhtadm -M -m 010011259B9C98 -e 'SrootPTH="/export/home/sol10_18b/Solaris_10/Tools/Boot"' dhtadm -M -m 010011259B9C98 -e 'SrootNM="sun10hw1"' dhtadm -M -m 010011259B9C98 -e 'SrootIP4=192.168.70.35' dhtadm -M -m 010011259B9C98 -e 'SinstIP4=192.168.70.35' dhtadm -M -m 010011259B9C98 -e 'SinstNM="sun10hw1"' dhtadm -M -m 010011259B9C98 -e 'BootSrvA=192.168.70.35' dhtadm -M -m 010011259B9C98 -e 'SbootURI=tftp://192.168.70.35/inetboot.I86PC.Solaris_10-1' dhtadm -M -m 010011259B9C98 -e 'SjumpsCF=192.168.70.35:/export/home/sol10_18b' dhtadm -M -m 010011259B9C98 -e 'SsysidCF=192.168.70.35:/export/home/sol10_18b' pntadm -A 192.168.70.44 -c sunblade1 -f PERMANENT -m (Command continued on next line) 010011259B9C98 -h sunblade1 -i 010011259B9C98 -s 192.168.70.35 192.168.70.0 |
As superuser, execute the dhtadm command in batch mode. Specify the name of the script to add the options and macros to your dhcptab. For example, if your script is named netinstalloptions, you would type the following command:
# dhtadm -B netinstalloptions |
Clients that have vendor client classes listed in the Vendor= string can now use DHCP for installing over the network.
For more information about how to use the dhtadm command, see the dhtadm(1M) man page. For more information about the dhcptab file, see the dhcptab(4) man page.
This section includes two procedures for creating installation options and macros by using DHCP Manager. The first procedure describes how to create installation options with DHCP Manager. The second procedure describes how to create installation macros with DHCP Manager.
Perform the following tasks before you create DHCP options for your installation.
Add the clients that you want to install with DHCP as installation clients of your network installation server. For more information, see How to Add Systems to Be Installed From the Network With add_install_client.
Configure your DHCP server, if it has not already been configured. For more information, see Configuring and Unconfiguring a DHCP Server Using DHCP Manager in System Administration Guide: IP Services and Configuring and Unconfiguring a DHCP Server Using dhcpconfig Commands in System Administration Guide: IP Services.
On the DHCP server, become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Start DHCP Manager.
# /usr/sadm/admin/bin/dhcpmgr & |
The DHCP Manager window is displayed.
Select the Options tab.
Choose Create from the Edit menu.
The Create Option dialog box opens.
Type the option name for the first option, then type values appropriate for that option.
Use the output of the add_install_client command , and the information in the tables in this section to check the option names and values for options that you must create. Notice that the vendor client classes are only suggested values. See Table 1–7. Create classes to indicate the actual client types that need to obtain Solaris installation parameters from the DHCP service. See Working With DHCP Options (Task Map) in System Administration Guide: IP Services for information about how to determine a client's vendor client class.
Click OK after you have typed all the values.
In the Options tab, select the option that you just created.
Select Duplicate from the Edit menu.
The Duplicate Option dialog box opens.
Type the name of another option, then modify other values appropriately.
The values for code, data type, granularity, and maximum are most likely to need modification. See Table 1–6.
Repeat Step 7 through Step 9 until you have created all the options.
You can now create macros to pass the options to network installation clients, as explained in the following procedure.
You do not need to add these options to a Solaris client's /etc/dhcp/inittab file because they are already included in that file.
Perform the following tasks before you create DHCP macros for your installation:
Create the DHCP options that you want to use in your macro. See Creating DHCP Options and Macros for Solaris Installation Parameters.
Start DHCP Manager.
Select the Macros tab.
The Create Macro dialog box opens.
Type the name of a macro.
Click the Select button.
The Select Option dialog box opens.
Select Vendor in the Category list.
The Vendor options that you created previously are listed.
Select an option that you want to add to the macro , and click OK.
Type a value for the option.
See Creating DHCP Options and Macros for Solaris Installation Parametersfor the option's data type and refer to the information that add_install_client -d reports.
Repeat Step 6 through Step 7 for each option you want to include.
To include another macro, type Include as the option name and type the macro name as the option value.
Click OK when the macro is complete.
The following table describes the tasks for booting a system from the network and instructions for performing a stand-alone installation of the Solaris OS with CD or DVD media.
Table 1–8 Booting and Installing the Solaris Operating System: Task Map|
Task |
Description |
For Instructions |
Boot the client system over the network. |
Begin the installation by booting the system from the network. | |
Install the Solaris OS on stand-alone systems with CD or DVD media. |
You can perform an initial installation of the Solaris OS on stand-alone systems by using the Solaris installation program. |
How to Install With the Solaris Installation Program on IBM BladeCenter Servers (Stand-Alone) |
Set up a serial over LAN connection to manage servers remotely. Note – This is an optional procedure that is performed after you have completed the Solaris OS installation. |
To manage systems remotely, you must first set up a serial over LAN connection. This connection provides access to the text console command prompt, which is necessary for managing servers from a remote location. |
This section describes how to boot a system and install the Solaris OS from the network by using PXE.
The open source GNU GRand Unified Bootloader (GRUB) has been implemented in the Solaris OS on x86 based systems, starting with the Solaris 10 1/06 release. GRUB is responsible for loading a boot archive, which contains the kernel modules and configuration files, into the system's memory. The Solaris kernel starts based on the contents of the in-memory boot archive. The kernel then begins the Solaris installation program. The most notable change is the replacement of the Device Configuration Assistant with the GRUB menu. The GRUB menu is displayed when you boot a system. From this menu, you can select an OS instance to install by using the up and down arrow keys. If you do not make a selection, the default OS instance is booted and installed.
As a part of this functionality, systems must have a minimum of 256 MB of RAM available for booting and installing the Solaris OS.
Some versions of PXE firmware cannot boot the Solaris OS. A system with these versions can read the PXE network bootstrap program from a boot server, but the bootstrap does not transmit packets. To avoid this problem, upgrade the PXE firmware on the network adapter. Obtain firmware upgrade information from the adapter manufacturer's web site. Refer to the elxl(7D) and the iprb(7D) man pages for more information.
To install the system over the network, you must instruct the client system to boot over the network. Enable network boot on the client system by using the BIOS setup program in the system BIOS, the network adapter BIOS, or both. On some systems, you must also adjust the boot device priority list so that network boot is attempted before booting from other devices. See the manufacturer's documentation for each setup program, or watch for setup program instructions during boot.
Starting with the Solaris 10 1/06 OS, GRUB based booting has been implemented on x86 based systems. This procedure includes information for booting a client over the network with GRUB. The most notable change is the replacement of the Device Configuration Assistant with the GRUB menu when a system is booted. For additional information about GRUB, see Chapter 11, GRUB Based Booting (Tasks), in System Administration Guide: Basic Administration.
This procedure assumes that you have completed the following tasks:
Set up an installation server. For instructions on how to create an installation server from CD or DVD media, see How to Create an Installation Server With x86 CD Media or How to Create an Installation Server With x86 DVD Media.
Set up a boot server or a DHCP server, if necessary. If the system you want to install is on a different subnet than the installation server, you must set up a boot server, or use a DHCP server. For instructions on how to set up a DHCP server to support network installations, see Part III, DHCP, in System Administration Guide: IP Services.
Gathered or preconfigured the information that you need to perform the installation. You can perform this task in one or both of the following ways:
Create a sysidcfg file, if you use a sysidcfg file to preconfigure system information. For information about how to create a sysidcfg file, see Preconfiguring With the sysidcfg File.
Create a profile in the JumpStart directory on the profile server, if you are using the custom JumpStart installation method. See How to Create a JumpStart Directory on a Server.
Turn on the system.
Type the appropriate keystroke combination to enter the system BIOS.
Some PXE-capable network adapters have a feature that enables PXE boot if you type a particular keystroke in response to a brief boot-time prompt.
In the system BIOS, instruct the system to boot from the network.
See your hardware documentation for information about how to set the boot priority in the BIOS.
Exit the BIOS.
The system boots from the network. The GRUB menu is displayed.
The GRUB menu that is displayed on your system might vary from the following example, depending on the configuration of your network installation server.
GNU GRUB version 0.95 (631K lower / 2095488K upper memory) +-------------------------------------------------------------------------+ | Solaris 11 /sol_11_x86 | | | | | +-------------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
Select the appropriate installation option.
To install the Solaris OS from the network, select the appropriate Solaris entry on the menu, then press Enter.
Select this entry if you want to install from the network installation server that you set up in How to Create an Installation Server With x86 CD Media or How to Create an Installation Server With x86 DVD Media.
To install the Solaris OS from the network with specific boot arguments, follow these steps.
You might need to set specific boot arguments if you want to modify the device configuration during the installation, and did not set these boot arguments previously with the add_install_client command as described in How to Add Systems to Be Installed From the Network With add_install_client.
On the GRUB menu, select the installation option that you want to edit, then press e.
Edit the command to add the boot arguments or options you want to use.
The command syntax for the Grub edit menu is as follows:
grub edit>kernel /image-directory/multiboot[kernel-name] install [url|ask] [-B prop=value[,prop=value]...] install_media=media-type |
For example:
kernel /I86pc.Solaris_11/multiboot kernel/unix -B install_media=192.168.2.1:/export/sol_10.1_x86/boot module /platform/i86pc/boot_archive |
Specifies the kernel to boot.
Prompts the user for configuration information.
Boots the system in single-user mode.
Specifies a reconfiguration boot. The system probes all attached hardware devices and then assigns nodes in the file system to represent only those devices that are actually found.
Boots the system with verbose messages enabled.
Does not boot in clustered mode.
Boots the system with the kernel debugger enabled.
Controls the boot behavior of the Service Management Facility (SMF). Included are two categories of options, recovery options and messages options.
Specifies an alternative executable as the primordial process. altinit is a valid path to an executable.
Is parsed by the multiboot program. The multiboot program then translates the argument into properties.
To return to the GRUB menu, press Esc.
To begin the installation, type b in the GRUB menu.
The Solaris installation program checks the default boot disk for installation requirements of the system. If the program cannot detect the system configuration, the program prompts you for any missing information.
When the check is completed, the installation selection screen is displayed.
The installation selection screen displays the following options:
Select the type of installation you want to perform:
1 Solaris Interactive
2 Custom JumpStart
3 Solaris Interactive Text (Desktop session)
4 Solaris Interactive Text (Console session)
5 Apply driver updates
6 Single user shell
Enter the number of your choice followed by the <ENTER> key.
Alternatively, enter custom boot arguments directly.
If you wait 30 seconds without typing anything,
an interactive installation will be started.
To install the Solaris OS, choose from the following options:
To install with the Solaris interactive installation GUI, type 1, then press Enter.
To install with the interactive text installer in a desktop session, type 3, then press Enter.
Select this installation type to override the default GUI installer and run the text installer.
To install with the interactive text installer in a console session, type 4, then press Enter.
If are performing an unattended custom JumpStart installation (option 2), see the Solaris 10 Installation Guide: Custom JumpStart and Advanced Installations additional instructions.
The system configures the devices and interfaces, and searches for configuration files. The kdmconfig utility detects the drivers that are necessary to configure the keyboard, display, and mouse on your system. The installation program begins. Go to Step 7 to continue the installation.
If you need to perform system administration tasks before the installation, choose from the following options:
To update drivers or install an installation time update (ITU), insert the update media, type 5, then press Enter.
You might need to update drivers or install an ITU to enable the Solaris OS to run on your system. Follow the instructions for your driver update or ITU to install the update.
To perform system administration tasks, type 6, then press Enter.
You might want to launch a single-user shell if you need to perform any system administration tasks on your system before you install the software. For information about system administration tasks you can perform prior to installation, see System Administration Guide: Basic Administration.
After you perform these system administration tasks, the previous list of installation options is displayed. Select the appropriate option to continue the installation.
If you are prompted, answer the system configuration questions.
If you preconfigured all of the system information, the installation program does not prompt you to specify any configuration information. See Preconfiguring With the sysidcfg File for more information.
If you are using the installation GUI, after you confirm the system configuration information, the Welcome to Solaris dialog box appears.
After the system boots and installs over the network, instruct the system to boot from the disk drive on subsequent boots.
If you plan to install multiple operating systems on your machine, you need to instruct the GRUB boot loader to recognize these operating systems in order to boot. For more information, see GRUB Based Booting (Overview) in System Administration Guide: Basic Administration.
You can install the Solaris OS by using the Solaris installation program. This section explains the tasks that you need to perform to install the Solaris OS, and provides detailed instructions on how to install the Solaris OS on a stand-alone system from CD or DVD media.
This procedure describes how to install a stand-alone system from CD or DVD media. Starting with the Solaris 10 1/06 release, the Solaris installation programs for x86 based systems use the GRUB boot loader.
Perform the following tasks before you begin your installation:
Ensure that you have the following media.
If you are installing from a DVD, use the Solaris Operating System DVD for x86 platforms for the Solaris release you are installing.
If you are installing from CD media, use the following:
Solaris Software CDs.
Solaris Languages for x86 Platforms CD – The installation program prompts you for this CD if necessary to support languages for specific geographic regions.
Check your system BIOS to make sure that you can boot from CD or DVD media.
Acquire any installation time updates (ITUs) or drivers that you need to install the Solaris OS on your hardware. To determine if you need an ITU or additional drivers, see your hardware documentation.
If you are installing the Solaris 10 11/06 OS on an IBM BladeCenter LS21 server, see Chapter 3, Troubleshooting Installation Issues on IBM BladeCenter Servers (Tasks) for important troubleshooting information regarding creating a new installation image.
Verify that your system meets the following minimum requirements:
Memory – 256 MB or greater
Disk space – 6.7 GB or greater
Processor speed – 120 MHz or greater with hardware floating point
If you are installing the Solaris OS on a system that is not produced by Sun Microsystems, Inc., check the Solaris Hardware Compatibility List at http://www.sun.com/bigadmin/hcl before you begin the installation.
Gather the information you need for installing the Solaris OS.
For a nonnetworked system, gather the following information:
Host name of the system that you are installing
Language and locales that you intend to use on the system
For a networked system, gather the following information:
Host IP address
Subnet mask
Domain name
root (superuser) password
(Optional) If you want to preserve any existing data or applications, back up your system.
Insert the appropriate media in your system.
If you boot from the Solaris Operating System DVD or the Solaris Software – 1 CD, insert the disc. Your system's BIOS must support booting from a DVD or CD. See your hardware documentation for more information about how to set the BIOS.
Boot the system by shutting it down and then turning it off and on.
If you need to manually set the BIOS to boot from CD or DVD, type the appropriate key sequence to interrupt your system boot process.
Modify the boot priority in the BIOS, and exit the BIOS to return to the installation program.
A memory test and hardware detection are executed, the screen refreshes, and the GRUB menu is displayed.
GNU GRUB version 0.95 (631K lower / 2095488K upper memory) +-------------------------------------------------------------------------+ | Solaris | | Solaris Serial Console ttya | | Solaris Serial Console ttyb (for lx50, v60x and v65x) | | | +-------------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
If you want to install the Solaris OS from CD or DVD on your current system, select Solaris, then press Enter.
Select this option if you want to install the system by using the default values.
If you want to install the Solaris OS and send the screen output to serial console, ttya (COM1), select ttya.
Select this option if you want to change the system display to a device that is connected to serial port, COM1.
If you want to install the Solaris OS and send the screen output to serial console, ttyb (COM2), select ttyb.
Select this option if you want to change the system display to a device that is connected to serial port, COM2.
If you want to install the Solaris OS with specific boot arguments, follow these steps.
You might want to use specific boot arguments to customize the system configuration during the installation.
On the GRUB menu, select the installation option that you want to edit, then press e to edit the selection.
Boot commands that are similar to the following text are displayed in the GRUB menu:
kernel /boot/multiboot kernel/unix -B install_media=cdrom module /boot/x86.miniroot |
Edit the command to add the boot arguments or options that you want to use.
The command syntax for the Grub Edit Menu is as follows:
grub edit>kernel /boot/multiboot kernel/unix/install [url|ask] -B options install_media=media-type |
The Solaris installation program checks the default boot disk for the installation requirements of the system. If the Solaris installation program cannot detect the system configuration, it prompts you for any missing information.
The installation selection screen displays the following options.
2 Custom JumpStart
6 Single user shell
Information in the installation selection screen might vary slightly, depending on which version of the Solaris 10 OS you are installing.
The system configures the devices and interfaces, and searches for configuration files. The kdmconfig utility detects the drivers that are necessary to configure the keyboard, display, and mouse on your system. The installation program begins. Go to Step 6 to continue the installation.
If you need to perform system administration tasks before your installation, choose from the following options:
You might need to update drivers or install an ITU to enable the Solaris OS to run on your system. Follow the instructions for your driver update or ITU for installing the update.
Decide if you need to modify the configuration settings.
If the kdmconfig utility cannot detect the video driver for your system, it selects the 640x480 VGA driver. The Solaris installation GUI cannot be displayed with the 640x480 VGA driver. As a result, the Solaris installation text installer is displayed. To use the Solaris installation GUI, use the kdmconfig utility to select the correct video driver for your system.
If you do not need to modify the configuration settings, let the Window System Configuration for Installation screen time out. Go to Step 7.
If you need to modify the configuration settings, follow these steps:
Press the Esc key.
You must press the Esc key within five seconds to interrupt the installation and modify device settings.
The kdmconfig – Introduction screen is displayed.
Examine the configuration information on the kdmconfig – View and Edit Window System Configuration screen, and determine which devices you need to edit.
Select the device that you want to change, and press F2_Continue.
Select the appropriate driver for the device, and press F2_Continue.
Repeat Step c through Step d for each device that you need to change.
When you are finished, select No changes needed – Test/Save and Exit and press F2_Continue.
Thekdmconfig Window System Configuration Test screen appears.
Press F2_Continue.
The screen refreshes and the kdmconfig Window System Configuration Test palette and pattern screen appears.
Move the pointer and examine the colors that are shown on the palette to ensure that they are displayed accurately.
If the colors are not displayed accurately, click No. If possible, press any key on the keyboard, or wait until kdmconfig automatically exits the kdmconfig Window System Configuration Test screen. Repeat Step b through Step h until the colors are displayed accurately and you can move the pointer as expected.
If the colors are displayed accurately, click Yes.
After a few seconds, the Select a Language screen is displayed.
Select the language that you want to use during the installation, and press Enter.
After a few seconds, the Solaris Installation Program screen appears.
If you are running the Solaris GUI installation program, the Solaris GUI Installation Program Welcome screen is displayed.
If you are running the Solaris text installer in a desktop session, the Solaris Text Installation Program Welcome screen is displayed.
Click Next to begin the installation. If you are prompted, answer any remaining configuration questions.
If you did not preconfigure all the system information, the installation program prompts you to specify this information on the next several screens.
After you answer the configuration questions, the Welcome to Solaris dialog box appears.
Decide if you want to reboot the system automatically and if you want to automatically eject the disc. Click Next.
The Specify Media screen appears.
Specify the media that you are using for the installation. Click Next.
Decide if you want to perform an initial installation. Click Next.
Select the type of installation you want to perform. Click Next.
Select Default Install to install the Entire Solaris Software Group.
Select Custom Install if you want to perform any of the following tasks.
Install a specific software group.
Install additional software.
Install specific software packages.
Install a specific locale.
Customize the disk layout.
The text installer does not prompt you to select a default or custom installation. To perform a default installation, accept the default values that are provided in the text installer. To perform a custom installation, edit the values in the text installer screens.
If you are prompted, answer any additional configuration questions.
When you have provided the information that is required for installing the system, the Ready to Install screen is displayed.
Click Install Now to install the Solaris software. Follow the instructions on the screen for installing the Solaris software and any additional software on the system.
When the Solaris installation program is finished installing the Solaris software, the system reboots automatically or prompts you to reboot manually.
After the installation is finished, installation logs are saved in a file. You can find the installation logs in the /var/sadm/system/logs and /var/sadm/install/logs directories.
If you did not select automatic reboot during the installation, reboot the system.
# reboot |
If you are installing the Solaris 10 1/06 OS, download and apply the latest revision of patch 118966. See 6339315: Bad Compiler Induces IBM BladeCenter HS20 Resets.
This bug applies to the Solaris 10 1/06 OS only. You do not need to perform this step if you are installing the Solaris 10 6/06 or the Solaris 10 11/06 release.
Patches can be downloaded from the SunSolveSM web site. For further instructions, go to http://sunsolve.sun.com/.
Reboot the system.
# reboot |
This section includes information about setting up a serial over LAN connection to manage systems remotely. Perform the following procedure after you have completed the Solaris OS installation. The BladeCenter Management Module (MM) command-line interface provides access to the text console command prompt on IBM BladeCenter servers through an SOL connection. If you want to manage systems remotely, you must first set up this connection. More information about the BladeCenter systems MM can be found at http://researchweb.watson.ibm.com/journal/rd/496/brey.html.
Change the values in the /etc/ttydefs as follows:
console:19200 hupcl opost onlcr:19200::console |
In the /boot/solaris/bootenv.rc file, change the ttyb-mode and console values as follows:
setprop ttyb-mode 19200,8,n,1,h setprop console 'ttyb' |
To eliminate the splash image and use ttyb at 19200, change the following information in the /boot/grub/menu.lst file:
#splashimage /boot/grub/splash.xpm.gz title Solaris 10 1/06 s10x_u1wos_19a X86 SOL kernel /platform/i86pc/multiboot -B console=ttyb |
If you are installing either the Solaris 10 1/06 or the Solaris 10 6/06 release on the HS40 BladeCenter server, add the following line to the asy.conf file:
name="asy" parent="isa" reg=1,0x2f8,8 interrupts=3; |
The IBM HS20 BladeCenter server has a BIOS update that addresses the missing COM2 port. If this port is not displayed by the BIOS, you can use the preceding workaround. Or, you can download the latest BIOS update from the IBM web site.
Reboot the system and run the devfsadm command.
Rebooting the system and running the devfsadm command ensures that the /dev/ttyb file has been created.
Initiate the SOL session by following these steps:
Telnet to the IP address of the BladeCenter Management Module.
# telnet management-module-ip-address |
Log in and type the following command:
console -T system:blade[xx] |
where xx is the bay number of the blade on which you want to initiate a session.
If the SOL connection is working, you should now have access to the text console command prompt.
If the connection is not working, the following error message is displayed:
SOL is not ready |
If the serial over LAN connection is not established, verify that the values you modified in Steps 2, 3, and 4 are correct. If necessary, repeat Steps 6 and 7 to establish the SOL connection.
