Solaris 10 11/06 Installation Guide: Custom JumpStart and Advanced Installations
Archive Stored on an NFS Server
If the archive is stored on an NFS server, use the following syntax for the archive_location keyword.
archive_location nfs server_name:/path/filename retry n
server_name
The name of the server where you stored the archive.
path
The location of the archive to be retrieved from the specified server. If the path contains $HOST, the Solaris Flash installation utilities replace $HOST with the name of the clone system that you are installing.
filename
The name of the Solaris Flash archive file.
retry n
An optional keyword. n is the maximum number of times the Solaris Flash utilities attempt to mount the archive.
Example 8–1 Archive Stored on an NFS Server
archive_location nfs golden:/archives/usrarchive
archive_location nfs://golden/archives/usrarchive
