Sun Cluster 3.1 4/04 Release Notes for Solaris OS
Sun Cluster HA for Oracle
In the online help file that is titled “Sun Cluster HA for Oracle,” in the section titled “Before Starting,” a note is incorrect.
Incorrect:
If no entries exist for shmsys and semsys in /etc/system, default values for these variables are automatically inserted in/etc/system. The system must then be rebooted. Check Oracle installation documentation to verify that these values are correct for your database.
Correct:
If no entries exist for the shmsys and semsys variables in the /etc/system file when you install the Oracle data service, you can open /etc/system and insert default values for these variables. You must then reboot the system. Check Oracle installation documentation to verify that the values that you insert are correct for your database.
