The following table summarizes the tasks for installing and configuring Sun Cluster HA for SWIFTAlliance Gateway and provides cross-references to detailed instructions for performing these tasks. Perform the tasks in the order that they are listed in the table.
Table 2 Tasks for Installing and Configuring Sun Cluster HA for SWIFTAlliance Gateway
Task |
Instructions |
Plan the SWIFTAlliance Gateway installation |
Planning the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration |
Install and configure SWIFTAlliance Gateway | |
Install the Sun Cluster HA for SWIFTAlliance Gateway packages | |
Register the Sun Cluster HA for SWIFTAlliance Gateway data service and configure the cluster for the data service |
Registering and Configuring the Sun Cluster HA for SWIFTAlliance Gateway |
Verify Sun Cluster HA for SWIFTAlliance Gateway |
Verifying the Sun Cluster HA for SWIFTAlliance Gateway Installation and Configuration |
Tuning the Sun Cluster HA for SWIFTAlliance Gateway fault monitor |
Tuning the Sun Cluster HA for SWIFTAlliance Gateway Fault Monitor |
(Optional) Debug Sun Cluster HA for SWIFTAlliance Gateway |
