Configuration Requirements
The configuration requirements in this section apply only to Sun Cluster HA for SWIFTAlliance Gateway.
Caution –
If your data service configuration does not satisfy these requirements,
the data service configuration might not be supported.
For requirements that apply to all data services, see Configuration Guidelines for Sun Cluster Data Services in Sun Cluster Data Services Planning and Administration Guide for Solaris OS.
You must configure Sun Cluster HA for SWIFTAlliance Gateway as a failover data service.
Create the following groups with the same group ID on all
cluster nodes or zones that can master the resource group: sagsnlg,
swnetg.
# groupadd -g groupid1 swnetg
# groupadd -g groupid2 sagsnlg
Create the following user with the same user ID on all cluster
nodes or zones that can master the resource group: swnet.
# useradd -u userid -g swnetg -d /home/swnet -s /usr/bin/ksh swnet
On Solaris 10 – Create a Solaris project called swift on all cluster nodes or zones that can master the resource group.
# projmod -s -K 'project.max-sem-ids=(privileged,1080,deny)' swift
# projmod -s -K 'project.max-sem-nsems=(privileged,512,deny)' swift
# projmod -s -K 'project.max-shm-memory=(privileged,4294967295,deny)' swift
# projmod -s -K 'project.max-shm-ids=(privileged,1200,deny)' swift
# projmod -s -K 'process.max-msg-qbytes=(privileged,10485760,deny)' swift
# projmod -s -K 'process.max-msg-messages=(privileged,8192,deny)' swift
The previous values are examples only. For more accurate values refer
to the SWIFTNet Link and SWIFTAlliance Gateway latest documentation release
notes.
On Solaris 10 — Assign project swift as
default project for swnet user by editing the /etc/user_attr file and adding the following line at the end of the file on all
On earlier versions of Solaris 10, refer to the SWIFTNet Link
and SWIFTAlliance Gateway latest documentation release notes for the required
setup in the /etc/system directory on all cluster nodes.
