The configuration restrictions in this section apply only to Sun Cluster HA for SWIFTAlliance Gateway.
If your data service configuration does not conform to these restrictions, the data service configuration might not be supported.
For restrictions that apply to all data services, see Sun Cluster 3.2 1/09 Release Notes for Solaris OS.
Sun Cluster HA for SWIFTAlliance Gateway supports SWIFTAlliance Gateway version 5.0, 6.0, and 6.1.
You can install the SWIFTNet Link and the SWIFTAlliance Gateway software only on a failover file system. If WebSphereTM MQ client software is needed for the operation of SWIFTAlliance Gateway, install WebSphere MQ client software on the local file system in the same path on each cluster node or zone that can master the resource group. The default path is /opt/mqm.
You cannot configure Sun Cluster HA for SWIFTAlliance Gateway as a scalable data service.
The Sun Cluster HA for SWIFTAlliance Gateway can be configured to run in a whole root or sparse root non-global zone for Sun Cluster HA for SWIFTAlliance Gateway version 6.0 or 6.1, if required.
