Sun Directory Server Enterprise Edition 7.0 Developer's Guide
slapi_entry_syntax_check()
This function determines whether the values of attributes present on the specified entry comply with attribute syntax rules.
Syntax
#include "slapi-plugin.h"
int slapi_entry_syntax_check( Slapi_PBlock *pb, Slapi_Entry *e );
Parameters
This function takes the following parameters:
pb
Parameter block.
e
Entry whose attributes to check for syntax compliance.
Returns
Returns one of the following values:
Memory Concerns
The pb argument can be NULL. It is used only to get the SLAPI_IS_REPLICATED_OPERATION flag. If that flag is present, no syntax checking is done.
